-   -   Any Tricks to Installing Trailing Arms? (http://forums.pelicanparts.com/porsche-911-technical-forum/607305-any-tricks-installing-trailing-arms.html)
rwest 05-07-2011 02:19 PM
Hello,
I've installed new bushings in my trailing arms, and they don't want to slide into the car mounts easily; one side will wiggle part way in, the other barely at all. Any one have any tips or tricks to get them in?
Thanks, Rutager
rusnak 05-07-2011 02:36 PM
I used a 2-ton hydraulic press to seat my new bushings. May be overkill, but once the bushings are fully seated your trailing arms will slide right in.
tobluforu 05-07-2011 03:12 PM
Like stated above, the bushings must be pressed in properly. You can use a bolt, slide it into the arm where the bushings are making sure you have big washers on both sides, put a nut on the other end and crank it down until bushings pop in. Maybe a tad bit of lube on the bushings so they will slide in easier.
