Home of the Whopper
6 point harness shoulder strap length?
Seems 50" is a common shoulder strap length on the 6 point harnesses. I measured what I thought I needed and came up with 55". What are you guys using? Is 50" enough and I measured wrong?
I am using a harness bar for now, but will eventually upgrade to a roll bar.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 05-10-2011, 07:02 AM
Shorter is always better. 55" must mean you are attaching at the back seat, seat belt anchors and over the guide bar. The straps do stretch in the event of a frontal impact and they can stretch quite a bit, so be mindful of that.
Tony G
2000 Boxster S
Old 05-10-2011, 09:49 AM
