Fast blink - only during first few minutes
My 80 SC has a weird issue with fast turn signal blinkers, both left and right. I've read this could be caused by a bad or loose bulb, or dirty contact, etc. I've checked my bulbs and cleaned out any dirt and contamination. They all looked pretty clean, but I sprayed electrical contact cleaner inside the housing, etc., just to be sure.
The strange thing about this issue is that it always seems to 'resolve' itself after a few minutes of driving. It's like the issue is eliminated once the car is warmed up. Its very consistent, never have a fast blink after a few minutes of driving. Does anyone have any suggestions as to what could cause a 'time sensitive' fast blink on the turn signals? Thank |
Just a guess: The relay could be on its' way out. When the relay is cold - fast blink. Relay warms up - all is well.
I would replace all the bulbs and relay. It won't be too expensive. I have a 944 that the blinkers don't work at all for a few minutes if the car sits more than a couple days.
make sure the bulb sockets are clean along with grounds. sounds like a high resistance problem
Thanks all for your responses...I'm ordering new relay and bulbs all around from our host. I will update with my findings on this strange issue.
BEST! Doyle |
Bad ground.
| All times are GMT -8. The time now is 05:49 PM. |
