magnumpi's Avatar
Fast blink - only during first few minutes
My 80 SC has a weird issue with fast turn signal blinkers, both left and right. I've read this could be caused by a bad or loose bulb, or dirty contact, etc. I've checked my bulbs and cleaned out any dirt and contamination. They all looked pretty clean, but I sprayed electrical contact cleaner inside the housing, etc., just to be sure.
The strange thing about this issue is that it always seems to 'resolve' itself after a few minutes of driving. It's like the issue is eliminated once the car is warmed up. Its very consistent, never have a fast blink after a few minutes of driving.
Does anyone have any suggestions as to what could cause a 'time sensitive' fast blink on the turn signals?
Thank
1980 911 ROW SC Coupe
2014 BMW 328i touring
1999 Porsche 911 C2
Old 05-08-2011, 02:18 PM
Danny_Ocean's Avatar
Just a guess: The relay could be on its' way out. When the relay is cold - fast blink. Relay warms up - all is well.
Old 05-08-2011, 02:37 PM
j911brick's Avatar
I would replace all the bulbs and relay. It won't be too expensive. I have a 944 that the blinkers don't work at all for a few minutes if the car sits more than a couple days.
james
www.gruppe9autowerks.com
Its not how fast you go...its how you go fast
Old 05-08-2011, 03:20 PM
T77911S's Avatar
make sure the bulb sockets are clean along with grounds. sounds like a high resistance problem
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 05-09-2011, 06:16 AM
magnumpi's Avatar
Thanks all for your responses...I'm ordering new relay and bulbs all around from our host. I will update with my findings on this strange issue.
1999 Porsche 911 C2
Old 05-09-2011, 08:11 AM
dshepp806's Avatar
+1 on that! One that resolves after it heats, so it's minor at this point. I bet if you clean all bulb contacts, this will disappear (I could be wrong,..but let's go for simplicity first!) Fresh bulbs wouldn't hurt a thing!
BEST!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 05-09-2011, 04:07 PM
rfloz's Avatar
Bad ground.
Bob F.
1984 Carrera Factory Turbo-Look
Old 05-10-2011, 08:59 AM
