-   -   Need Help Identifing Alternator. (http://forums.pelicanparts.com/porsche-911-technical-forum/607502-need-help-identifing-alternator.html)
1976 TN Porsche 05-08-2011 05:20 PM
The alternator I took out of my car is the dirty one and I have know idea what brand or amp it is. I bought the other alternator from someone here on Pelican but it is different it to short and my fan belt rubs the shroud. I did make it work but it only wants to charge with running at about 3000 RPM. Can someone till me was Kind,Brand and AMP alternator I need. Could you also identify the alternators I have. My car is a 1976 911S. Thankshttp://forums.pelicanparts.com/uploa...1304900287.jpg
http://forums.pelicanparts.com/uploa...1304900319.jpg
http://forums.pelicanparts.com/uploa...1304900344.jpg
mholbrook38 05-08-2011 05:25 PM
Have you tried to find an auto electric shop in your area. Perhaps they could rebuild your original alternator...good luck.
Flat6pac 05-08-2011 05:39 PM
By 76 the alternators were Motorola. What is the voltage regulator?
There is different back spacing on the fan housings between the years and voltages.
911.603.120.02 Generator 980-w for 75 on Motorola (taken from the PET)
Bruce
1976 TN Porsche 05-08-2011 05:50 PM
Bruce' The voltage regulator is a Marchal. Does anyone have a good used one. I can't rebuild mine because I broke the top housing trying to get fan off. Thanks Craig.
Flat6pac 05-08-2011 06:21 PM
Ive got some voltage reg but have another idea. you have a PM
Bruce
Driver_X 05-09-2011 05:49 AM
I believe you can just order a replacement from our host. The smaller of the two alt's is harder to find. I have a '74 and I ran into this last fall...
Link: http://forums.pelicanparts.com/porsche-911-technical-forum/572956-alternator-question.html
