fxeditor's Avatar
Electric seats stopped working
Hello all,
I recently learned that the electric seats have stopped working in my '87 coupe. Since I never adjust my seat I'm not really sure how long this has been an issue but neither the driver's nor the passenger seats perform any or their electric functions. I know they did at one time. My question is could this be a fuse or relay problem? I looked at the fuse box and didn't see anything labeled "seats" or such, am I missing something?
Thanks in advance for any advice!
Michael
-- '87 Diamond Blue Coupe
-- '92 Miata
-- '06 Scion XB (the wife's)
-- '01 Audi S4 (Sold)
-- '17 Tesla Model S60
Old 05-13-2011, 06:32 PM
Justin@Athens's Avatar
Send a message via AIM to Justin@Athens
look again...it should be the second fuse from the end closest to the driver.
1990 964 C4 Coupe & 1991 964 C2 Coupe (current)
1989 911 Targa (sold)
1996 993 Cab. (sold)
1999 x2 Boxster (sold)
2006 Cayman S (my daily)
Old 05-13-2011, 07:00 PM
djcdmv's Avatar
If it's not the fuse, try cleanig the switch contacts on the seat with contact cleaner.
Dave
Black 1985 911 Carrera M491
Old 05-13-2011, 07:09 PM
steely's Avatar
+1 on the switches -
this might help too
"how-to" fix power seat switches......
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 05-13-2011, 07:12 PM
fxeditor's Avatar
Thanks for the advice on the switches but since it's both seats that have the problem I am gathering that's not the issue. But since I'm there I might as well clean them anyways!
Michael
-- '92 Miata
Old 05-13-2011, 07:24 PM
Super_Dave_D's Avatar
Recently I found out the same thing - the wire-harness that plugs into the seat had come loose and lost connection. Look at the connection before you send money on the switches - they are not cheap.
2015 Audi S3
1988 Carrera Coupe (gone and miss her)
Old 05-13-2011, 10:21 PM
dshepp806's Avatar
+! on the fuse take.
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 05-14-2011, 03:20 AM
fxeditor's Avatar
Well I checked fuse #2 and sure enough it had blown so off to the Autozone I went. Got home, proceded to plug the new fuse in when I got this badge of courage:
The fuse blows in my hand. Ouch! Lesson learned, don't work on the electrical components without disconnecting the battery!
Well, my second new 25amp fuse in the assortment kit, fell into no man's land so off I went to Pep Boys to get some more. I get home and find out that the fuse blows instantly upon putting it into the socket (and connecting the battery). SO my new question is where do I go now? Electrical troubleshooting isn't my strong suit but is there anything blatant I should look for?
Thanks again for all the help,
Michael
-- '92 Miata
Old 05-15-2011, 05:31 PM
well, that's odd! I'd get your voltmeter out and see how much juice is running through that circuit. I'd also unplug your power seats one at a time to see if its a bad switch or bad wiring under the seats. Unplug one side, and if the problem does not go away plug it back in and move to the other seat.
One of my seats is hard wired into the car as those female 8 pin connectors that are part of the car's wiring loom aren't cheap and sometimes disintegrate at the solder points. You might need to visit here:link to used female pwr seat plug
That is just a guess though, I think the seats are supposed to be on switched power, although mine aren't--but I should go fix that I guess.
Good luck!
Old 05-15-2011, 05:57 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Been there done that , damn it stung!
OK, you have a short under the seat. There are 2 set of wires (Blue if I recall and Ground) of 4.
Check to see if there is a short or crimped wire.
When I placed a sub-woofer under the passenger seat, one of the spaded wires was exposed and touching the metal part of the seat. Placed some heat shrink, no more issues.
Also note, make sure AC is turned off, it shares the same circuit.
'85 Carrera Targa
PCA/POC
Wash. State
nesslar's Avatar
Yeah, maybe the wiring to the seats is crimped and bared between the seat sliders.....but seriously, whatever, sounds like a real life dead flat short to me; could be most anywhere along the line/circuit/wiring. I'd start checking the wiring under the hood, then under the seats and at the switches.
Old 05-15-2011, 06:07 PM
hold fuses on the sides so that doesn't happen. just fixed a seat on an '85 that had two broken bare wires underneath.
206 637 4071
Old 05-15-2011, 06:55 PM
dshepp806's Avatar
+1 there. Sorry that happened to you, mate. Burns are no fun. They must be handled as JW suggested,..better withour power (my quick disconnect has been convenient in these type of cases)..
..probably (but not absolutely) a loose (hot) wire touching ground (as suggested). Red wire will be the +12 VDC feed to all of the switches' pin #2.
GOOD LUCK!
Doyle
Middle Georgia
Old 05-15-2011, 08:38 PM
