wwwcad's Avatar
What's this green light for?
I'm working on a wiring job and was wondering what the green indicator light in the bottom center is supposed to be for? I can't find it on the 911 wiring diagrams in the forum.
Old 05-10-2011, 06:11 AM
db_cooper's Avatar
Should be a "park lamps" indicator. Comes on with the first notch in the headlamp switch.
Old 05-10-2011, 06:55 AM
I think that (at the bottom of speedo) is an indicator for when the fog's are on.
Would have to check for sure.
Hope the UPS girl leaves mine on the steps today from North Hollywood Speedometer having the odometer fixed.
Regards
Old 05-10-2011, 07:07 AM
schumicat's Avatar
it is pkg light indicator like db cooper said. they moved it to the top of the speedo in later years.
Regards
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 05-10-2011, 07:17 AM
911freek's Avatar
OK, now I Have a question too... There is a vertical knob at the bottom of the gauge board situated between the speedo and teh tacho and above the wiper delay switch (it is visible in the above pic). I looked inside the dashboard, it is connected to a cable that has a hex-head at its end and in my case, is completely loose.
This is probably the panel dimming or something, but what is it supposed to be connected to? Currently its just a mechanical wire turning knob.
My preferred concert venue? The driver's seat of an open-top 911.
Old 05-10-2011, 07:49 AM
db_cooper's Avatar
The fog lamp indicator is in the pull knob. It comes on when fogs are in the on position.
Old 05-10-2011, 07:51 AM
db_cooper's Avatar
I think your talking about the odometer reset knob.
Old 05-10-2011, 07:53 AM
BlueWing's Avatar
I think my green light comes on with my "city lights". I have ROW H4s.
Terry
79 SC Minerva Blue ROW
Non Sunroof Crank Window Coupe
3.0 SSIs, Backdated Heat
COA: Passenger Side Mirror, Manual Antenna & Dunlop Tires
Old 05-10-2011, 07:59 AM
wwwcad's Avatar
Wow, thanks guys, this really helps! The light socket has 2 terminals, so I'll have to figure out what's what. Wiring/electrical is the very least of my rebuild skills!
I just got the speedo and clock back from North Hollywood and they did a fantastic job rehabing them. The speedo is a replacement for a badly rusted out one and it broke my speedo cable the first time I ran it. I also bought it for my 912 (the seller said it was from a 912) and I didn't notice it had a slightly different terminal configuration and a top speed of 150! Duh. I need to work on my attention to detail.
Anyway, we'll fix her up thanks to your input.
Another question, does the green light stay on if you pull the light switch all the way out for the headlights or should it go off?
Old 05-10-2011, 08:16 AM
wwwcad's Avatar
Yep, you need to reinstall it into the back of your speedo and then you can reset the trip meter setting.
Old 05-10-2011, 08:18 AM
Grady Clay's Avatar
wwwcad,
I see a 1967-68 912 (or is it a ’67-68 911 normal).
From my original 1968 911 (normal) Owner’s Manual, it says: “Also located on the [speedometer] dial face is a control lamp indicating that the parking lights are on.”
Here is part of the diagram from :
http://www.pelicanparts.com/911/911_Parts/Electrical/911_electrical_1965.jpg
This (red arrow) agrees with the wiring diagram in my ’68 Driver’s Manual.
Be careful to not confuse white/green with green/white in this diagram.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 05-10-2011, 09:14 AM
911freek's Avatar
Thanks guys. The speedo was probably replaced by the PO, and has the front button for reset.
FYI - My park brake indicator was on the temp/press gauge.
Old 05-10-2011, 11:36 AM
wwwcad's Avatar
The front button is different! Must be an upgrade or newer model.
Old 05-10-2011, 12:17 PM
Quantum Mechanic
mpetry's Avatar
Send a message via Yahoo to mpetry Send a message via Skype™ to mpetry
It's a warning to let you know they are on - the parking lamps are used in Europe, in cities without headlights, back in the day. Some flavors of the Euro H4 headlamp had a small bulb at the bottom that was wired into the parking lamp circuit, and ROW cars had an extra wire pigtail for that.
I believe that cars so equipped also had their turn signals set up so that they stayed on (steady) when parked if the turn signal switch was set and the key off, again per european rules.
Mark Petry
Bainbridge Island, WA
81 SC
Old 05-10-2011, 12:22 PM
schumicat's Avatar
even the US SCs have the feature where the turn signals stay on steady with key off, it is to keep cars from running into you when parked. mercedes always have that too (using headlight switch positions instead of turn signal switch).
the extra little bulb in euro lights you are thinking of is the "city light." a couple of cities had the idea that you would use a low wattage light in the city instead of headlights. I think they gave up on that very quickly. parking lights are different; all cars have parking lights, even GM products.
Old 05-10-2011, 02:45 PM
