redstrosekNic's Avatar
Porsche Crest Transmission Crossmember
After a large amount of research, I've found only two people who use their transmission crossmember as a rear jack point. Since my case is magnesium, I'm not jacking it up by that. I also have no access to the factory jack points, as my car is a Strosek conversion. Jacking rear of car-method (Look near bottom of page 2) Anybody have a reason not to use this as a jack point? Thanks very much for the input! I apologize for bringing up a topic that has been discussed at length.
Dustin
Old 05-12-2011, 08:21 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Why not give it a try and report. Makes total sense as long as a block of wood is used to distribute the weight along the crossmember and importantly to the chassis
I raise from the engine with a pad, freakin POs did not use a pad so she is scuffed up on the engine halves
Heck, maybe it will not premature weaken the engine mounts with the raise from trans mount method?
'85 Carrera Targa
PCA/POC
Old 05-12-2011, 08:43 AM
I just used the crossmember to jack the car up. It worked very well. Two pieces of 2X4 to spread the weight out, and (obviously) jack stands as a safety while I was changing the brake fluid. Worked out very well, and I will no longer wonder where to lift the rear of the car by.
Dustin
Old 05-12-2011, 09:06 PM
DRACO A5OG's Avatar
Good News, glad it was uneventful
Jim
'85 Carrera Targa
PCA/POC
Old 05-12-2011, 09:52 PM
