1980 porsche 911sc starting issues
hey everyone,
i have a 1980 porsche 911sc.
it wont start, the battery is charged, the fuel pump engages, the relays have all been changed.
it used to do this, then after a couple of tries or leaving it for 30 mins or so. it would then start.
but now for the last 3 days i am unable to get it going unless i push start it.
any ideas?
its going to a porsche specialist in a weeks time, but whilst i still have it hear, i want to try and get it going myself.
Cheers
Adam
Old 03-01-2013, 01:00 AM
Honey Badger
theFONZ's Avatar
Does it turn over? Does it sputter? Do you just hear a click when you turn the key? With no more info, I'd guess starter or solenoid. Try tapping the starter with a wrench or something and see if it will start then.
1978 911SC
1953 Piper PA-18A
USAF EOmfD
Old 03-01-2013, 01:50 AM
al lkosmal's Avatar
Adam,
You need to provide a bit more info for us to provide you with some help.
but here are a couple simple checks, based on a broad assumption.
If your starter is not turning the engine over to get it started, but you can push start it, I'd check the ground strap that is located by the transmission mount. Remove it and clean all the mounting surfaces and try starting again.
I'd also check to see that the yellow wire is connected to the starter. If it is disconnected the starter will not be energized.
regards,
al
PS: Provide some more info and we can go from there.
RGruppe #669
http://www.x-faktory.com/
Old 03-01-2013, 06:58 AM
all the accesories work, i can hear the fuel pump ,
but when i turn the the key it doesnt click, it doesnt turn over at all = no spluttering.
im assuming its the starter motor or the solenoid.
Old 03-01-2013, 03:56 PM
ToddM's Avatar
Send a message via AIM to ToddM Send a message via Yahoo to ToddM
Starter solenoid.. common failure.
-Todd
'82 911 SC Coupe w/'92 3.6L, bulletproofed 915/62 w/GT LSD & Wevo goodness, Rennsport RSR/Bilstein Sport, SRP ARB, ER Polybronze, BK strut brace, 15x7/8" Fuchs.
Sold: 92 964 Turbo, 81 SC, 96 993 Coupe, 82 SC, 89 Carrera Cabriolete
Old 03-01-2013, 04:24 PM
al lkosmal's Avatar
no start
Originally Posted by al lkosmal View Post
Adam,
regards,
al
Adam,
Start with the simple stuff 1st. I've fixed two no-start conditions by cleaning/replacing the ground strap and one by plugging the yellow wire to the starter back in. If that doesn't work for you....move on to the more costly and difficult.
regards,
Al
RGruppe #669
Old 03-01-2013, 07:07 PM
Hunt3R's Avatar
What he said.
Same thing just happened to me. Same symptoms you describe, and it was intermittent at first too, then left me stranded unless push-started. Then it would start again the next day. Then for the next 3 days it wouldn't. I followed this tech article to verify it was the starter solenoid but suffice to say the new starter works great.
http://www.pelicanparts.com/techarticles/mult_starter_diag/mult_starter_diag.htm
Old 03-02-2013, 03:36 AM
so if the starter solenoid is gone, does that mean i have to change the starter motor?
Old 03-02-2013, 03:38 PM
Here's another potential problem. Your post indicates that the fuel pump is running even when the key is not in the start position. If that's the case, your fuel pump relay circuit is faulty. The fuel pump should not run unless the engine is running or the engine is rotating by the starter motor (and it would be difficult to hear the pump due to the noise of the starter.) It could be the relay, intake safety switch, or wiring to the switch. This is a separate issue than the failure of the engine to turn over via the starter. Get that taken care of and then address the fuel pump issue.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 03-02-2013, 03:52 PM
Thanks for all the replies everyone
As most of you thought, it was the starter solenoid.
It's getting replaced, and I have asked my mechanic
To clean out the ground strap and all the wires in that area.
Old 03-04-2013, 11:56 PM
aquazulu2's Avatar
I had a similar problem, in checking the fault I jumperd the sylenoid and the main starter connection, starter worked, with the jumper but not at ignition. Fault was found to be a coroded ground strap bolted on transmission and frame. Braded ground strap left of the starter.
Old 03-05-2013, 05:22 AM
What about your fuel pump? Does it run with the ignition on but the engine not running, as implied by one of your posts? If so, fix it also.
L.J.
Old 03-05-2013, 07:33 AM
