-   -   Help Identifying Plug (http://forums.pelicanparts.com/porsche-911-technical-forum/608576-help-identifying-plug.html)
hesmart 05-13-2011 11:39 PM
Hi Everyone,
I was cleaning the carpet, when I found a plug underneath the drivers seat that was not plugged into anything. Anyone know where it goes? From a 86.
http://i31.photobucket.com/albums/c3...t/IMAG0115.jpg
http://i31.photobucket.com/albums/c3...t/IMAG0112.jpg
BMWDavid 05-14-2011 02:33 AM
I was wondering that as well. Saw that plug a while ago under my seat.
hcoles 05-14-2011 07:56 AM
You may want to have your car tented. :-)
vracer 05-14-2011 08:59 AM
They were still putting the same plug in cars in '89. (That is for information only; someone else will have to answer the question. I hope.)
Hendog 05-14-2011 09:24 AM
Now I see why you were cleaning the carpets:eek:
http://forums.pelicanparts.com/uploa...1305390215.jpg
As for the plug, I have the same one going nowhere...
hcoles 05-14-2011 12:42 PM
passenger side electrical seat power?
vracer 05-14-2011 06:05 PM
Nope. My seats are electric everything, except heated.
pete3799 05-14-2011 06:40 PM
Seat belt buzzer?
Just a guess.
fat cab 05-14-2011 06:46 PM
find the other end you get 37.5 more horse power
kidrock 05-14-2011 09:11 PM
It's an electronic worm-zapper. It's supposed to be unplugged, it fools the worms. It looks like it's working perfectly.
Jrboulder 05-15-2011 12:02 AM
Seat heater?
jmod 05-15-2011 04:54 AM
What are the colors of the wires going to the connector?
Being under the drivers seat could be something to do with the DME. Altitude correction unit?
BMWDavid 05-15-2011 06:32 AM
Well I looked around again and found the other plug that goes into this. I plugged mine together but don't notice anything.
I bet it has something to do with the seat belts...
hesmart 05-15-2011 09:13 PM
do you happen to know where the other end of the plug was?
BMWDavid 05-16-2011 02:19 AM
It was near the seat...both plug ends were under the carpet.
vince_aust 05-16-2011 06:09 AM
seat belt indicator plug - other end plugs into seat belt harness - my guess
porschenut 05-16-2011 06:47 AM
That's the connector for the inside temperature sensor mounted on the dash, just to the left of the climate controls. It plugs into the heater control box between the seats. You can see it here clearly in the picture:
http://forums.pelicanparts.com/uploa...1305553655.jpg
hesmart 05-16-2011 12:37 PM
Porschenut,
Thanks so much! Exactly what I was looking for.
BMWDavid 05-16-2011 05:39 PM
Not on my car...I don't have the temp sensor as I have the manual heat system. Perhaps on my car it does have something to do with the seat belt indicator.
Since my dash lamp cluster is not working I can't see if it is the seat belt warning.
Hendog 05-16-2011 06:30 PM
Not on mine
I believe Porsche might have run the wires wether required or not for the sake of efficiency at the factory. Those cars which required it got it plugged into the circuit board, those that didn't, well, didn't. I have the plug, but like many others, it's not plugged into anything. Keep in mind, in the days of the Carrera (mid-late 80's ) Porsche was pumping out a lot of cars, relatively speaking, to the yuppies. Porsche probably (conjecture) tried to streamline production by wiring all the cars the same and then just plugging in the options that were ordered.
I don't have climate control, therefore the cirlced portion on the dash is not populated with the sensor. Also note my control between the seats only goes up to 3. I believe the climate controlled cars have detents up to 10 (I may be wrong on this).
http://forums.pelicanparts.com/uploa...1305595738.jpg
http://forums.pelicanparts.com/uploa...1305595777.jpg
