Wheels spacer size?
I have am 85 Targa and I am installing 17 x 7 and 17 x 8.5 996 twist Italian after market wheels. The offsets are ET 55 Front and ET 50 rear.
My question is, what is the best size spacers to use that will fill the fenders? I am planning on running 225/45R17 and 255/40R17 tires, have not bought them or the spacers yet. All help is much appreciated
85 Targa |
best thing to do is set them under the car where you like them and measure the hub air gap, Kevin
DP911.....
If it helps I just installed 993 Cup 17" wheels to my 87 Coupe for DE 17", 55 ET front and rear, used 1.5" spacer on the rear and 1" spacer on the front. Went with 245/40/17 rear and 225/45/17 fronts, and I could certainly have used 255's Neil
Neil 1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic (X) [B] 2011 BMW X5[B] 'Success is not final, failure is not fatal. It is the courage to continue that counts' |
Member 911 Anonymous
You'll need longer studs as well, take care make sure they are not too long or the lugs will bust right thru.
Buy some extra lugs for the spare, the longer studs will certainly break thru
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
