Car runs on 5 cylinders until warmed up
Took my car out of the mothballs this weekend. Idle at startup is very rough-seems to be running on 5 cyls. Wires are about 5 years old. Complete rebuild 2 years ago. After a long drive runs fine. What to check?
John Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance. |
Member 911 Anonymous
Have you tried the "spray a mist of water in the dark to see if there are any errand sparks from the wires?"
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Have not. Just water?
Yeap H2O, borrow the spray bottle from Mrs and spray a mist at the wires.
It is possible when warm the rubber expands and temporarily seals the wire/s
