Weber linkage part number
I can't seem to find a diagram for the linkage. Is there a part number or name for this part? I need it and want to buy one (if anybody has one?).
Cross bar linkage to the bell crank.
DD summer/winter: 2000 Boxster S
DD spring/fall: 914-6 w/ 3.0L SC Dual Webers (For Sale)
http://imgur.com/a/k0Wtl - My 914-6 Build/Project Story
Old 07-05-2011, 08:33 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Its item 19 in the parts diagrams (check out the PET pdfs linked to Porsche's site via Pelican's catalog)
http://www.porsche.com/all/media/pdf/originalparts/usa/911-1_USA_KATALOG.pdf
Look under group 1 engine, then subgroup 107.
901 108 648 00 and it's called "pull rod"
The ball sockets are item 21 part number 900 169 001 02
But all this pull rod really is, is a partially threaded length of M5 threaded rod. You could easily make your own out of a piece of fully threaded rod from your local hardware store (if they actually have metric threaded rod).
Edit.......... I looked up the above part numbers on Pelican's catalog and surprisingly the pull rod is still available and only $9.25. The ball sockets are $14 each!
Kevin L
'86 Carrera "Larry"
Old 07-05-2011, 09:03 AM
I need to stop looking at the parts diagram just on Pelican's site and use the PDFs. Much more detailed and fulfilled. Then I wouldn't have to post asking!
Was looking all over on the website for that diagram
Thanks I appreciate it!
I'm sure my local ACE which carries metric would have a rod. But would need to figure something out for the ball sockets.
Old 07-05-2011, 10:00 AM
Scott R's Avatar
I believe I have a few of these exact rods, I can check when I get home and you can have it for the cost of shipping.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 07-05-2011, 10:57 AM
