NutmegCarrera's Avatar
Location: Plymouth Wi. - Spitting distance from Road America
O2 sensor equivalency
Fellas-
I have read (here) that a suitable O2 sensor can be had from a '96 Taurus. I have also read that we should be looking for a 3-wire.
My research (not real wide-scope at this point) has been that the '96 Taurus uses a 4-wire.
Are there other suitable "donors" to source this sensor from? Looks like other model years (earlier) of the Taurus use a 3-wire.
What is sacred, and what is not?
Obviously, we won't be getting signal / bandwidth specs from billy-bob at the car parts store, but I'm thinking that a 22mm and 3-wire will do it.
Just looking for any other x-ref vehicles to pull one from (new, at the parts store - of course).
Thanks Much!
Old 05-19-2011, 05:30 AM
grateful user
don gilbert's Avatar
if your car has a three wire, you can swap to a one wire from o'rilies for 20 buck. the 2 extra wires are for heating the 02 up faster for emission reasons. saves you a good chunk of change, and you will never know the difference as far as drivability goes.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 05-19-2011, 07:00 AM
Thanks, Don.
But, given a choice - I'd prefer to keep three wires. I guess the 4-wire is o.k., as I just don't have a home for #4. In the OBD vehicles - I understand that this is just feedback. I just hate having to guess on which wire is which.
Looking for a good reference vehicle for that 3-wire sensor.
Thanks!
Old 05-19-2011, 09:51 AM
oh snap's Avatar
Anyone know the answer to this? A part number from someone who has done it would be great
1985 Iris Blue M491 911 Coupe
Old 05-30-2012, 08:48 PM
the normal [not wideband] sensor puts out 0 to 1 volt on the sensor wire. One wire only has this wire and the shell is the ground.
Three wire adds 2 more wires for the heater element that is an electric heat to heat up the O2 sensor more quickly.
There is not magic here. .5 volt is the right mixture and the O2 sensor reads back and forth to either side of that.
The 2 leads that give you resistance on an Ohmeter are the heater. The other is the sensor lead. Simple as that.
Does not matter much if it is Bosch or whatever.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 05-30-2012, 08:58 PM
Ahh, the never-ending quest for a dirt cheap O2 sensor. Pelican sells a universal 3 wire sensor for $71.75. That's about what I pay for my oil at every oil change. Seems cheap enough.
I have a used OEM 3 wire off of an SC or turbo I'll sell ya. It's pretty clean.
JR
Old 05-31-2012, 05:48 AM
Flat Six
Flat Six's Avatar
I bought mine (Bosch OE fitment for 85 Carrera - w/proper connector and through-tin grommets) for less than $80. Bosch part number 13003
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 05-31-2012, 01:29 PM
oh snap's Avatar
Thanks for that info flat 6. For $80 I won't bother with splicing in a universal, now I just need to find it in Canada.
Old 05-31-2012, 01:54 PM
Flat Six
Flat Six's Avatar
oh snap -- sent you a PM
Dale
Old 05-31-2012, 02:03 PM
dshepp806's Avatar
I just installed a fresh Bosch O2 sensor,.....not too much worried about the price......not into splicing stuff on the O2...she's running abit better, I would add,..and the sensor was removed without any problems...NICE!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 05-31-2012, 02:27 PM
