Upgrade to SC radius arms
Hi, can anyone tell me; If I upgrade the radius arms on my 69E to the adjustable SC type, what other components will I have to change (i.e. Rear shocks etc)?
Thanks in advance Adam |
adjustable SC spring plate radius arms are a direct bolt-on for your LWB car. You just need the hardware. Make sure you get the adjustable hardware (adjustment cam and locking bolt) to go with them. They are expensive to replace.
This is also a good time to replace the rubber bushings which have, no doubt, cold flowed over the years. |
Thanks Jamie...much appreciated.
| All times are GMT -8. The time now is 01:34 PM. |
