Upgrade to SC radius arms
Hi, can anyone tell me; If I upgrade the radius arms on my 69E to the adjustable SC type, what other components will I have to change (i.e. Rear shocks etc)?
Thanks in advance Adam
71 Bahia Red 2.2E (sold) 72 Silver 2.4 T (stock except for a 2.8 big bore kit) 69 Chartreuse 2.0E |
I would rather be driving
adjustable SC spring plate radius arms are a direct bolt-on for your LWB car. You just need the hardware. Make sure you get the adjustable hardware (adjustment cam and locking bolt) to go with them. They are expensive to replace.
This is also a good time to replace the rubber bushings which have, no doubt, cold flowed over the years.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Thanks Jamie...much appreciated.
