Chain fence eating turbo
Clutch slave cylinder rebuild kit for '87 C3.2?
As the title says, is there a kit available?
I found kits for 944's and 968's only so far.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 05-20-2011, 08:16 AM
Easily Confused
dtxscott's Avatar
I haven't seen one. When I had the drivetrain out of my car a few months ago, I bought a new slave.
Scott C.
'08 Cayenne GTS 6MT : '89 Targa GP White/Black - "Oliver's Car" : '11 Mitsu Evo X : '08 Lexus IS350 F-Sport : '01 Toyota Sequoia : 1998 Yamaha V-max : 1979 BMW R65
Old 05-20-2011, 11:16 AM
87 - 911
1987 - My slave cylinder started failing last fall, replaced it with a new one from our host while I had the engine & transmission out for top end work.
The Slave can be replaced in the car, but you need to be in a zen like state. Access is miserable from under the car, and bleeding is a royal pain. The fluid that came out of mine looked horrible, the lack of access leads people not to bleed the circuit, eventually the moisture in the fluid ruins the seal.
Before replacing you may want to try bleeding the lines to see if that helps.
Old 05-20-2011, 04:55 PM
Justin@Athens's Avatar
Send a message via AIM to Justin@Athens
bump for the same question
1990 964 C4 Coupe & 1991 964 C2 Coupe (current)
1989 911 Targa (sold)
1996 993 Cab. (sold)
1999 x2 Boxster (sold)
2006 Cayman S (my daily)
Old 05-21-2011, 05:09 AM
