Hi
Brake Booster Vacuum Hose
NEVER MIND. THIS HAS ALREADY BEEN ANSWERED.
I SHOULD HAVE CHECKED MY NOTES BEFORE POSTING......D'uh. Can anyone tell me what size and length the vacuum hose (brake booster) is in the engine compartment. ![]() This is the hose that goes from the engine bay and then disappears underneath the car. ![]() (1984 Carrera 3.2) Thanks
"A good sense of humor is the best thing to have in your toolbox when working on these cars." Quote by Charles Freeborn, Pelican. Last edited by Targa Me; 02-17-2011 at 08:56 AM.. |
Member 911 Anonymous
I am curious too, where does it start in the engine bay?
Jim
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Nevermind, found it, right next tot he Fuel Filter running out along the hard fuel lines and connected to connector with he small T fitting connected to the vacuum of the Cruise Control.
So 19MM OD. Has anyone ever try to fish it out by disconnecting it from the bottom at the tunnel then clamping a replacement hose to the end and pulling the whole thing out the engine bay or the reverse, clamping from engine bay and pulling from the bottom? Hate to splice but if that is the best route then I will. Jim
Hi
That brake vac hose runs into the engine bay at the same location of some of the a/c hoses. If you have your a/c hose still in place, and Jim i think you're still using your a/c, then you won't be able to pull that brake vac hose through...too tight of a fit.
"A good sense of humor is the best thing to have in your toolbox when working on these cars." Quote by Charles Freeborn, Pelican. |
Mr. Walker discusses it here too:
vacuum leak you probably didn't ever think of
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Thank Steely & Targa Me.
I am aware of the thread but only remedy would be is to splice. I was afraid of that TM, damn AC
That's cool/ok - I think he's (John) is an advocate of the splice.
Easily Confused
I did this job with the engine out of the car and it was a PITA. With it in the car, it would be a major PITA.
Scott C. '08 Cayenne GTS 6MT : '89 Targa GP White/Black - "Oliver's Car" : '11 Mitsu Evo X : '08 Lexus IS350 F-Sport : '01 Toyota Sequoia : 1998 Yamaha V-max : 1979 BMW R65 |
Yeah, looked at the routing, WTF?
Well it is on my list on next engine drop, geez!
