LinkBack Thread Tools Rating: Thread Rating: 3 votes, 2.33 average.
I would rather be driving
jpnovak's Avatar
Very Cool. nothing like the first fire of a motor when building a new project.
Old 09-12-2011, 08:41 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #141 (permalink)
MBruns for President
JeremyD's Avatar
Hey - my alternator is not working - not showing a charge - do I have to get the single pulley conversion for the upper fan too? just bought the lower single pulley
I have this -
do I need this to make sure my alternator works?? V Looks like just the fan is spinning now...
Patrick Motorsports - PMP 36FAN-HUB FAN DRIVE HUB ENGINE CONVERSION 3.6L 3.8L RS RSR ALTERNATOR SINGLE BELT DRIVE PULLEY PORSCHE 911
Old 09-12-2011, 09:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #142 (permalink)
loose nut behind wheel
cudabnu's Avatar
Single or dual pulley doesn't matter on the charge, did you take a volt meter and confirm the no charge? I don't remember doing anything special for the Alt when I did my 3.6 conversion.
oops, I see since you did the single lower pully change, then yes you do need the single upper conversion.
80 911sc/993 GT-2 body/3.6L motor
71 VW Convert (300 hp 2332 FI turbo)
97 Passat TDI 320K miles and counting
Old 09-13-2011, 07:38 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #143 (permalink)
Tom '74 911's Avatar
Oh the glorious sound of an engine's first start!!!!
I have a Patrick crank pulley and a Rothsport fan pulley - not sure why I ended up w/that combo but anyway. . . My alternator light on the dash/gauge comes on when I first start it up. As soon as I rev it past 2K, it goes out for good.
Per KTL's post above - when I first wired everything up, I had that issue w/the red wires at the 14 Pin connector. I didn't disconnect them and back fed the system. My gauges and lights were all funky. Fortunately, there was no apparent damage and when I finally disconnected them, it was all good.
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 09-13-2011, 07:39 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #144 (permalink)
Mr. C
SAY - 642's Avatar
Awesome, Jeremy....beautiful sights & sounds!
Old 09-13-2011, 08:10 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #145 (permalink)
My 3.6 conversion does the same thing, the light stays on until the car has hit 2k rpm once and then it is out til I start the car again.
Old 09-13-2011, 09:49 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #146 (permalink)
JeremyD's Avatar
Per Patrickmotorsports - you need the top hub (that they sell, obviously) with the single pulley lower - to keep the shaft stable = otherwise the fan moves - but the alternator does not {because the fan is on a bearing that slides onto the alternator shaft}
I knew it wasn't charging because #1 I have a voltage gauge in place of the oil level gauge - and #2 I have a voltage determined red led light on my dash that signals anything under 12 volts (which would indicate a broken belt and a no charge situation)
Old 09-13-2011, 10:09 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #147 (permalink)
JeremyD's Avatar
and yes, I try and follow KTL's advice - and made sure I disconnected the red #2 wire so I didn't get feedback. In fact - I pulled all the lines off that I didn't use and capped them off - I'm surprised my car ran to tell you the truth with the 2.7 - the T30 14 prong plug was pretty corroded. now all updated with marine grade wiring and heat shrink. I may look for a 6 prong plug that I can connect and disconnect easily - just used 6 bullet connections from harness to harness.
Old 09-13-2011, 10:13 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #148 (permalink)
JeremyD's Avatar
Couple of resources for the engine pin / chassis harness for those that follow this course in the future
HELP Please! with another 1973 3.2L implant
Yes you do need both the top and bottom pulleys to make the alternator work.
Patrick has good stuff - but their customer service blows.
Check out rothsport - good stuff.
The conversion is not really too bad - it's all the supporting stuff that makes it a pain in the butt (and takes up alot of time) probably set me back 2-3 weeks messing with the fuel line upgrades and moving the pump (but len cummings makes replacement fittings and lines - good stuff)
Wiring is another - probably could have cobbeled together something - but no - everything has to be marine grade, heat shrunk, etc...
Third thing is the transmission - changing from the mag case - to a carrera 915 - with a cooler - LSD - etc. change drive shafts and then adding some WEVO bits - added to the expense - and the time.
Hopefully it will all be worth it in the long run...
Old 09-28-2011, 07:07 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #149 (permalink)
arrivederci's Avatar
This might belong in another thread...but what 915 strengthening options can be made to work with the factory euro trans cooler? I have one from an '84 and also have the 108mm flanges. But nothing else had been done to beef up the 915.
- '72 911T
- '81 911SC Euro
Old 09-28-2011, 07:16 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #150 (permalink)
JeremyD's Avatar
If you open it up - put the one piece bearing retainer.
Without opening it up - put provisions for a cooler and at least the side plate. The billet side plate uses (typically depending on mfg) 930 bearings (which a much meatier than the 911 varient)
You want to stop the side from deflecting under acceleration. Also adding a LSD can help too - but it adds a little heat ~ 10 -20 degrees was quoted to me.
Sooooooo... with my research - and talking to people that are smarter than me = I added a provision for cooling (wevo shift plate pick up and temp sender) wevo side plate - with 930 bearings. AN fitting on top of the differential cover - AND a tilton pump and big a cooler fitted to my decklid.
pump
cooler and lines can be seen here
Wevo goodness
Old 09-28-2011, 07:36 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #151 (permalink)
LJ851's Avatar
Those wevo parts sure look nice! It's hard to tell from the pics if the pump is isolated from the body (rubber mounted). I'm going to assume you did but if not you will want to.
Old 09-28-2011, 08:05 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #152 (permalink)
ShakinJoe's Avatar
Shame on you for asking this!!!
Jeremy is changing his Avatar to "King of Overkill"
He actually does everything right, but then just does it better!!!
'87 Carrera - 2400 lbs of Track Beast!!
'88 Carrera Cab - Too nice for the track.
'85 Targa - Salvage title that was not caught!
Old 09-28-2011, 08:16 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #153 (permalink)
JeremyD's Avatar
HA HA - sickness really -
Old 09-28-2011, 08:42 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #154 (permalink)
JeremyD's Avatar
OK - just to close this out.
The car is back on the road - have a few minor items to sort out - but should be able to knock out in a reasonable amount of time.
From my other thread on the car - more information here; Well here she is -
reflecting back - this is a pretty big job. Probably more to do with me stripping the engine down to clean and change some of the seals. Like John said - the 3.6 engines really should be stripped down to the case and resealed. And actually there is quite a bit of truth to this.
There are two spots where it is leaking a little oil - both on the cam covers - the seals that I did not replace - where the covers join at the side of the case. really cause I didn't want to have to re time the cams. Still, I'm glad I changed the seals that I did change. I'll have to live with an odd drip.
In reflection - I really set up the car when I redid last year - suspension wise, brake wise and cooling wise. Even then - I didn't replace the fuel lines and relocate the fuel pump - both turned into bigger jobs as I had to remove a majority of the front suspension to get to them.
Even though I read a fair amount - I was unprepared regarding the engine harness to chassis harness - Figured you buy the conversion harness from Patrick - that's what you need - right?
Also regarding the alternator - if you go with the single pulley conversion - with the early car engine tin and carrier - you still need the single alternator pulley.
Right now I'm still figuring the engine oil temp sender (gauges have early sender, engine has later dual pole) and speedometer - had to convert to later electronic version... of course with no wiring harness.
SO anyway - it's in - and running -
EDIT - ended up running a separate line for the oil thermostat line - the other one kept shorting out and giving false readings. I also changed out the thermostat to an older style - so the pressure no longer reads twice the actual.
Old 10-03-2011, 09:13 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #155 (permalink)
Jeremy -
Congrats on getting it running and back on the road. I'd agree w/you - it is a big job. Lots of little details that add up sucking time & $$.
I converted to an electric speedo too. I ran 2 new wires from the dash, to the rear of the center tunnel where they connect to the speedo sensor wires; stock-like I think. Not too bad to do.
After driving my car all summer, I still have some little things to sort out. It will never end - but then again, what would I do with all the extra free time and money if it did end? : )
Tom
Old 10-03-2011, 09:52 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #156 (permalink)
Great project and I've been watching all along. I am on a similar path, although my '72 is getting prepped on a rotisserie in my garage before I send it out for paint. I put what I think are the finishing touches on my 3.6 this weekend, bolting up the PMS flywheel, etc. I'm sure I will have some things to do when I start trial fitting the motor / tranny since they will both be new to my chassis...working out the kinks with airbox/air filter clearance, engine mount spacers, factory trans cooler, second fender mount oil cooler, fuel lines, etc etc etc.
Not trivial. But at least you've built a great reference for me and future 3.6 installs. Thanks!
- '72 911T
- '81 911SC Euro
Old 10-03-2011, 10:02 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #157 (permalink)
DW SD's Avatar
Don't forget that you knocked out a chunk the project when you added the second oil cooler the previous go-around.
I upgraded to the Hargett cam covers and still get leaks there. those are frustrating to solve. My 3.2 never leaked. The 964 cover design seems a great improvement, yet in practice it doesn't seem to work the way they should (in preventing leaks).
Doug
1971 RSR - interpretation
Old 10-03-2011, 10:57 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #158 (permalink)
JeremyD's Avatar
My 3.2 was bone dry - my mag case 2.7 never dropped any oil - but my 964 c2 targa leaked like a sieve - go figure...
Old 10-03-2011, 11:50 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #159 (permalink)
Brando
quattrorunner's Avatar
Sub for info
Turbo powa!
1977 911s. it's cool
Old 10-13-2011, 04:21 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #160 (permalink)
