89 AC refresh or replace?
Hi All,
Next week i pick up a new to me 89 conv. The car has been maintained great with the exception of the AC which has nit worked or been used in about 10 years. Since it's been in the Bay Area not much need. I have read a bunch of posts about replacement etc but I wanted tonsee what parts I could salvage. Should i have the compressor rebuilt and replace hoses or do I need a new compressor for the new refrigerant? Any and all suggestions welcomed. Will post pics when I pick it up. My son and I are planning a x country drive to get it home. |
Contact Griffiths.com and all will be revealed. Also find a good, local, old school a/c shop run by a guy old enolugh to be your father. Added points for grease under fingernails.
Richard 1989 Venetian Blue Targa |
+1 on Griffiths
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Young enthusiast
Depending on how bad the A/C system is, start by recharging the refrigerant and checking for leaks. If that doesn't work, consider a fan install or system replacement. These 3.2L Carreras definitely aren't known for their icy A/Cs though..
BULLET 1989 Porsche Carrera 3.2 coupe |
SAIGON 68
if you have a ragtop, why would you want air conditioning?
I'm just going through this process myself. I'd say, with respect, that it's not worth the money to put in a refrigerant, which in all likelihood will simply leak out.
911 special 1984 to 1989 package [911special1984to1989package] : Griffiths Technical Inc Which is a drop-in replacement for most of the system which is likely in your car. Assumes your compressor is good. Have spent some time on the phone with Charlie Griffiths. His knowledge and his products both seem good. Hope this helps.
89 Carrera 3.4 "There is a right way to go around a corner - it's called the line." -- PCA DE speaker bryteside.com - good things happen. |
Thanks for all the info. Is there any way to check to see if the compressor is still working or are they pretty sturdy?
1989 Cabriolet 1970 911E Sold |
Another +1 for Griffiths!!
70 911T Sold 81 911SC Coupe84 Mustang Turbo GT 66 Galaxy 500 Ragtop (my Mother bought it new) 88 Thunderbird Turbo Coupe 69 Torino Cobra (R) Code |
You also have to consider that the system is a quarter century old. So even if it is still functional it's nearing the end of its useful life and there are more modern and efficient components availabe and lots of upgrades that will make the AC a lot better than it when it was new. It just depends on how much you want to spend. If you decide to upgrade, plan on at least $1500 if you do most of the work yourself. You can have cheap or you can have good but you can't have both. Good luck! And congrats on your 'new' 911.
1986 Carrera Coupe 1999 Chevy Tahoe 1987 Chevy Blazer 1955 Chevy Apache 3100 Pickup "A little knowledge is a dangerous thing" |
if anyone finds a good AC shop in NorCal that is good at assisting with this sort of project, please post
Shortly after the compressor clutch engages you should see a transition from gas (NOTHING!) to bubbles (plain to see) to liquid refrigerant, NOTHING again. Reverse for compressor clutch off. If you do not see this transition that might also mean a low, TO LOW, refrigerant level and you shouldn't be running teh compressor at all. |
By that measure so is the engine itself and so it would be best to spend that $1500 there. "..nearing the end of it's useful life.." That's exactly the words used to describe the state of our office building's HVAC system 10 years ago now, 2 or 3 V-belts, system blower drive belt, changes later. I have a freezer here at home that is at least 30 years old and still working well. There are only 3 working/moving parts in your A/C, the cabin blower, teh condensor blower, and the compressor. |
This post comes about two hours after I pulled the trigger. Oh well, I'll have peace of mind.
If you suspect the latter then I would wipe the backside of the v-belt pulley, nearest the compressor, clean and then check for oil contamination there after a few days of A/C use. |
Maybe true if it was $1500 engine....
