-   -   SC front fogs (http://forums.pelicanparts.com/porsche-911-technical-forum/610845-sc-front-fogs.html)
deeking55 05-27-2011 05:24 AM
SC front fogs
OK, so my 83 had the dreaded front battery rust - after all is said and done, I have a nearly new front end. Problem is, after updating my front valance and months at the body shop, I cannot locate where the front fogs plug in or how they are wired. As it did not have fogs when I bought it, I have no comparison. Can anyone enlighten me where the front wiring harness is or where I should be looking?
cheers-
schumicat 05-27-2011 06:44 AM
there was a thread about fog light wiring last week, which should be locatable in a search.
deeking55 05-27-2011 12:08 PM
I appreciate it -didn't realize Pelican had that stuff online.
gtihop 05-27-2011 03:42 PM
There is a 2 pin plug on the inside of the front trunk for the fogs. One on each side of the inner fender. The wiring runs up from the fogs through a grommet in the inner fender and plugs in to the harness. The plug is a clear type with 2 flat blade pins.
RSWiser 05-27-2011 07:40 PM
Just did this on my 80SC. There is a small rubber grommet (hole) going into the each side of the trunk.
I just put one lead through at a time and it hooks up to the plastic plug in side the trunk.
Pictures please.
wwest 05-28-2011 10:33 AM
cheers-
Just leave them unpowered, fog lights are more for "looks" than any real functionality anyway. Headlights MUST be used during legal nightime hours, over-shadowing fog lights making their light pattern USELESS.
Even here in the PNW the need for functional use of fog lights is RARE.
