SC front fogs
OK, so my 83 had the dreaded front battery rust - after all is said and done, I have a nearly new front end. Problem is, after updating my front valance and months at the body shop, I cannot locate where the front fogs plug in or how they are wired. As it did not have fogs when I bought it, I have no comparison. Can anyone enlighten me where the front wiring harness is or where I should be looking?
cheers- |
there was a thread about fog light wiring last week, which should be locatable in a search.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
I appreciate it -didn't realize Pelican had that stuff online.
There is a 2 pin plug on the inside of the front trunk for the fogs. One on each side of the inner fender. The wiring runs up from the fogs through a grommet in the inner fender and plugs in to the harness. The plug is a clear type with 2 flat blade pins.
1983 911 SC 2015 Volks GTI 1991 Volks GTI 2011 Nissan Juke 1992 Nissan NX 2000 |
80 911 SC, Orem, Ut
Just did this on my 80SC. There is a small rubber grommet (hole) going into the each side of the trunk.
I just put one lead through at a time and it hooks up to the plastic plug in side the trunk. Pictures please.
Rob 1980 911 SC |
Even here in the PNW the need for functional use of fog lights is RARE. |
