915 Shifter Front Bushing Replacement
Quick question about access to this set screw:
When the shift coupler between the rear seats is loosened
does this allow the shift rod to rotate enough to access
the set screw in the front?
Tom
Old 07-26-2010, 08:09 AM
Friend of Warren
Why do you need to do that? The bushing is actually a nylon part that fits into that cup in your picture.
Kurt V
Old 07-26-2010, 08:39 AM
Bushing replacement
No not the cup bushing, the bushing for the shift rod support piece.
Thanks,
Tom
Old 07-26-2010, 08:46 AM
Yes, it does. I just replaced mine. MAKE SURE YOU MARK THE COUPLER AND ROD before you loosen it so you can line it up properly when you tighten it back up.
Also, have some really hot water ready so you can soften the bushing, even with that its a real PIA to get it.
1983 SC - sold
2002 996 C4S - sold
1968 912
Old 07-26-2010, 08:59 AM
Techne's Avatar
I removed the whole rod, wasn't hard.
1984 911 Carrera
Old 07-26-2010, 09:44 AM
Packy's Avatar
PITA, +1 to remove the whole rod.
(1) '77 Chassis and '79 SC 3.0 project car
(1) '79 911SC 3.0 Widebody SC
(1) '15 Ford F-150 4x4 3.5TT
Toluca Lake, CA
Old 07-26-2010, 11:13 AM
No. The shift coupler does not have to be removed to replace the front shift tube bushing.
Carry a spare wherever you go - just in case. This happened at the Monterey Historics last year - a Porsche year yet, and the closest dealer-supplied part was sitting in Germany. Luckily Dave Loop (Dave Loop European, Del Rey Oaks) saved the day.
BTW, this bushing lasted about 9 years with this configuration, but wear is steady, gradual and inevitable.
Sherwood
PS: The set screw isn't shown.
Old 07-26-2010, 11:50 AM
schumicat's Avatar
I loosed that set screw without first loosening the rear coupling. If you remove the bolts on the shift housing, you can reach the set screw with an allen wrench (and then with fingers once it's loose).
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 07-26-2010, 11:52 AM
shifter bushing replacement
I asked about loosening the shift coupler because I am unable to get in there with an Allen key! I can get the key inserted but am unable to turn it. Just wanted to make sure the entire shift rod turns when the coupler is loosened. I do plan to replace all the shifter bushings since I am installing a Seine Gate shift kit.
Thanks for all the help everyone.
Tom
Old 07-26-2010, 12:07 PM
Yes, just loosen the shift coupler. The entire rod will rotate and make the set screw very easy to remove up front. You will most likely want to adjust the coupler anyway after replacing the shift bushing.
It is very easy to adjust the coupler.
Old 07-26-2010, 12:47 PM
BTW, the set screw on my shift lever bushing cup has a square head and factory-drilled to allow safety wire (see example photo). It's a lot easier than an internal hex to remove and replace.
Sherwood
Old 07-26-2010, 01:28 PM
r_towle's Avatar
Sherwood
Are those little square headed safety wire bolts still available?
Rich
Old 05-27-2011, 05:55 PM
