Weltmeister strut bar correct mounting
see photos what is the correct mounting of this bar do the mounts attach to the painted surface of the shock towers? is there any spacer between the mount and the painted surface? would like to see a copy of instructions can email to bdcox42@gmail.com of a correct photo
thanks in advance ![]() ![]() ![]() |
Before you mount it, you might want to modify it. Look this up and you will see what I'm referring to.
72 911 Although it is done at the moment, it will never be finished. |
bar
did that thanks
Northern Motorhead
I just removed my cracked Weltmeister hardware after welding one of the strut brackets twice,i welded in some RSR strut brackets instead ...
Like Toblu mentions,cut out the hole for the shock bolt otherwise your brackets will crack just like mine ! They mount directly to the shock tower and i didn't have any spacers with my installation ... Cheers ! Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
muck-raker
those are some ugly welds
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations ![]() |
+1 on the welds, looks like poor penetration, not tig welded I bet. I'd be suspect of the welds cracking, even though clearance hole was opened up for the shock bolt.
