Car started to smoke very badly yesterday.
Yesterday During my 85 911 3.2's annual inspection - part of the inspection involves jacking up the rear end to check suspension.
Car was running during this - revs were heard to fall slightly then both pipes started kicking unreal amounts of smoke - I switched the thing off after this - it was pretty hot. The 5 mile drive home - car went okay but for most of the journey - I couldn't see what was behind me. It's now cleared up and exhaust is clean again but at the time - I thought I had holed a piston or similar - question being - where and how did this oil get into the exhaust. Cheers |
RETIRED
Sounds like you sucked oil from the tank into the intake.
Hire out as a mosquito killer..... Not an uncommon issue when you leave a steep drive way and you have over the 1/2 mark on your dipstick. Drive it.....burn it.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
drain some oil off, drive another 30 miles and clear out its throat.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
I gave the thing a service when I got home - but left the oil half way up the stick instead of the usual 7/8's - really cannot believe the smoke it kicked out!
All appears well now so I suppose it's time to enjoy the thing over the summer. Cheers |
Mine did that once.
I had the rear jacked up doing spring plate bushings. Had to leave on a week long trip before i finished. After i got back and finished up i fired it up and it filled the garage with white smoke. Never done it since.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
83 911 Production Cab #10
Too much oil in the tank.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
