Thought i'd add my experience. I've got an '85 carrera with a magnaflow muffler and i put a 93 octane SW chip in it. I have not dyno tested it , but there was a noticeable improvement in bottom end torque . I could not feel a noticeable improvement in peak power.
Organ Donor
I've noticed a defnite improvement at low speed torque and throttle control. The car also seems to be smoother at higher revs, and the redline's electronic limiter was raised a bit. Still haven't done the premuffler and exhaust, but I may get around to it.
Sorry to pimp my own thread, but I took a couple of pictures when I installed the chip back here. |
Welcome to pelican,
I've been looking for an answer to the same question. I have a SW chip, I do think it makes a difference (some would argue thats a placebo effect). 101 projects book from this site has some good things in it for you to do to your car that aren't too expensive. I've heard over and over again that people don't know how good their car really is until they go the track, and to not mod it till you have. It does take good driving to master these cars but i haven't made it myself. I'm now into weight reduction but thats a different story, best upgrade for your car plus free at first. |
MBruns for President
euro premuffler - dual out sport exhaust - Steve Wong chip
Bets bang for your bucks. From there the cots go up astronomically - the benefits not so much.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Organ Donor
The number 10 pin was an issue that was raised that applies to California cars only. The fat wire connector that runs to the DME under the drivers seat has a smaller wire with brown connectors running adjacent to it. These wires are disconnected in 49 state vehicles.
If you have a California car, this wire might be connected, in which case it should be disconnected on installing the chip. It is my undertanding that then the number ten pin issue is solved, by having no connection along this wire. |
One modification I would suggest is fitting a Momo Prototipo steering wheel (or similar).... they really do look and feel good.
Gman Last edited by Gman993; 06-06-2011 at 12:09 AM.. |
Young enthusiast
An immediate improvement may cost you a total of $0. Especially if you live outside California and Japan (where they have strict emissions requirements), ensure the Pin 10 wires, which are next to the thick black DME cable beneath the driver's seat, are disconnected.
BULLET 1989 Porsche Carrera 3.2 coupe |
If you can find a good alignment shop, new shocks, lowering and corner balance will get you ready for track days, along with new brakes pads.
As for the SW chip and cat bypass, I have never heard anyone who wasn't happy with that mod. These are the easy things that make a 911 more like itself. Stripping out weight is also a popular low cost option. Many start with the AC and rear seats. |
Um, a good Porsche alignment shop, that is...
Having trouble loading pictures via Flikr. Anyone else?
On Tour
Nice looking 3.2.....love the color combo
For the patient instuctive types: what is changed within the maps when one simply removes the cat/converter and allows the engine to "breathe"....? And, to what degree? I have to agree with Loren (thus far), as these "do" seem to contradict,..I mean, it IS what is,..what, in fact, is it? Surely, there's an answer,..a clear one.... Of course, I'm the dumb-arse who never knew (rather, noticed) that my (89) baby was loaded with an Auto-Authority chip (for almost 1 1/2 years of ownership!) .....requiring nothing less than 92 octane gas (which, of course, I always run non-ethanol 93 octane from day one) .....I've not checked any of the parameters on this specific chip, thus far, but AM MOST interested to know more about it. Looking to put the Wong chip on board soon......I hope to get the part # to Steve so that he can read what's there (vs. how he does things)....I'm NEVER comfortable with changes (especially ignition advance) being unknown when the system DOES NOT have knock sensing and associated controls. BEST! Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Flat Six
On the surface this seems like a contradiction but I don't think it really is.
If I read this correctly, Jerry Woods is saying -- in effect -- don't go looking for anything more than marginal overall (e.g., peak) HP gains by opening up the intake tract (MAF, K&N, ExtrudeHone, etc.) 'cause you won't find it. [Emphasis mine] Quicksilver seems to be saying aftermarket chip = gains on otherwise stock motor w/ignition & fuel mapping. My interpretation is that re-mapped fuel & ignition can produce some marginal overall (e.g., peak) HP gains at the risk (very little / some / a lot of risk, depending on who's chip you buy) of detonation and other woes. Besides peak power, however, I'd believe the greater benefit of remapped ECU/DME on an otherwise stock motor would come in the form(s) of throttle response, mid-range power, etc. I'm by no means an authority, but that's how I read it. Jerry Woods & Quicksilver, my apologies if I've misinterpreted/misrepresented your positions. Dale Quote:
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
Formerly known as Syzygy
Also check that you're getting full throttle opening - real cheap (about $0) and quick (half hour if you take your time). It seems that many cars' linkage is out of adjustment and aren't getting full throttle. Lots of threads on this...
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
| Tags |
| 3.2 , performance upgrades |
