Hendog's Avatar
What next? Removing struts
I've gotten this far; ball joint pins out, wheels off. I have this camber strut brace by PO installed. What is my next step in getting the struts out?
Thank you for the help.
Henri
Owned for 21 years: '87 Carrera coupe Venetian blue
Old 06-05-2011, 03:19 PM
Hendog's Avatar
To answer my own question: I did have to remove the camber strut brace to get the strut to come out of the upper mount. Besides, to change the rubber bushings the brace had to come out. Onward...
Henri
Old 06-05-2011, 04:24 PM
Almost Banned Once
sc_rufctr's Avatar
Are you replacing the struts?
- Peter
Old 06-05-2011, 04:26 PM
schumicat's Avatar
if you're just changing the inserts (as opposed to the whole strut housing), you don't need to remove the ball joint pin. you just need to compress the strut and pull it out of the wheel housing (don't let it hang by brake line) and remove the roll pin at the bottom (bilstein) or big nut at the top which holds the insert in place.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 06-05-2011, 04:41 PM
