				No low beam headlights
			Hi, replaced bulbs, still no low beams, any ideas?
			Welcome to Pelican, post pic's of your car and tell us about it? Everything you should need is in this excellent thread:
			turn signal switch quick fix pictures
	Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles  |
			When this happened to my car it was corrosion at the fuse panel.
			 Member 911 Anonymous
	'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC  |
			Had same problem on my 86 Carerra - was the high low beam stalk switch - apparently these are prone to failure!
	AKA "86ragtop" 1986 911 Carrera SOLD 11/2001 1984 Carrera 3.2 IROC RSR look  |
			Replaced my stalk in my 85 after having this problem.  Problem solved.
	Dave Black 1985 911 Carrera M491  |
			see if the two low beam fuses are getting 12V first. no power, suspect the hi/low switch, which often can be tweeked into functioning again. plenty on that if you search.
	https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071  |
			If it hasn't been done already, add a headlight relay.  From the factory all of the headlight current goes through the stalk which contributes to its failure.
					Pelican Parts - Product Information: JWST-911-HLPR
	1986 Carrera Coupe 1999 Chevy Tahoe 1987 Chevy Blazer 1955 Chevy Apache 3100 Pickup "A little knowledge is a dangerous thing"  |
