-   -   How to Diagnos a mechanically DEAD 3.2 Distributor, sorry only fix is to Buy Another (http://forums.pelicanparts.com/porsche-911-technical-forum/612712-how-diagnos-mechanically-dead-3-2-distributor-sorry-only-fix-buy-another.html)
BURN-BROS 06-08-2011 10:05 AM
I offer a rebuild service for distributors as well.
http://forums.pelicanparts.com/uploa...1307552622.jpg
http://forums.pelicanparts.com/uploa...1307552726.jpg
DRACO A5OG 06-08-2011 10:48 AM
Originally Posted by gtc (Post 6067700)
I don't see how even a degree or three of misalignment would give you trouble. It's the motronic doing the timing, right? I thought the mechanical advance mechanism simply got the rotor roughly lined up with the correct terminal inside the cap every time the coil fired.
This is what I thought on a 3.2 and later Carreras.
This is totally, anecdotal and only my personal experience but when I tested my dizzy after my attempts of a DIY rebuild, she did run quiet and normal until I took her up to 80 MPH, then the buzzing started however she did not skip or struggle in anyway.
But still better safe then sorry, I also purchased a known good one for $150. I tested about four of them in a bin by spinning them and looking for smoothness with a bit of resistance. I learned if it spins too FREELY without any resistance, that is signs of a soon to be Bad Dizzy.
Wow, his prices have not changed in 3 years :eek: that is OLD SCHOOL FOR Yeah.
Jim
DRACO A5OG 06-08-2011 10:52 AM
Do you also custom make the internal bushings for the 3.2 Distributors? SmileWavy
Jim
BURN-BROS 06-08-2011 11:18 AM
I do, as well as the internal seal if necessary. It is rare that bushings are out of spec if proper lubrication is maintained.
The failure process is this;
1. lack of oil to the upper fiber shim quickly causes it's failure. Excessive endplay is the warning sign that a service is necessary but there is a good chance that the bushings are still within spec.
2. If the distributor is left in this state the upper bearing rate of failure is quite rapid. I normally see this failure on 3.0liter SC distributors and all have had evidence of water damage which I assume is from washing the engine but could be contributedto other events.
DRACO A5OG 06-08-2011 11:26 AM
Thank Sir Aaron
Barry H, stated those shims are NLA ( he called it Vycon/Vyton or something like that ).
Please forgive me but How does one oil it? In the Car or Remove Lube and Replace?
May I also ask how you feel about the position of the sprocket, there is only two ways it can go on the end of the shaft. 0 degrees 180 degrees from initial removal, No?
BURN-BROS 06-08-2011 11:41 AM
Other than the 356/912 distributors there is no alignment problem.
As far as lubing, I would do it out of the car and figure out a way to get oil to the upper shim.
DRACO A5OG 06-08-2011 11:52 AM
Intriguing.
Maybe an oil bath then drip dry wipe access off :confused:. I do not want dismantle ever again, I will leave it to your shop ;)
Thank you again sir!
rusnak 06-08-2011 05:23 PM
That totally concides with my experience. From making noise, the failure was about 50-60 miles. That's why the only thing you can really do is to check the end play annually or more for older distributors. The failure can create a fire, or take the catalytic converter.
I think fastening that little gear is critical. If it falls off, you might be looking for a new block.
BURN-BROS 06-08-2011 06:04 PM
Agreed, I am a bit concerned by roll pins walking out.
DRACO A5OG 06-08-2011 06:15 PM
Great another reason not to use my spare :eek:
HFR_Racer 06-08-2011 06:37 PM
Have you ever seen a properly installed roll pin walk out on one of these? I've got a dizzy that the main shaft and gear were machined out to 3/16" and a double roll pin was installed. I've been running this with no issue thus far.
DRACO A5OG 06-08-2011 06:40 PM
McMaster-Carr does have the steel TAPER PINs in Metric sizes as well.
HFR_Racer 06-08-2011 11:53 PM
I'm sorry, but you are way off base here. The factory pin is NOT what your calling a TAPERED pin which is seen in McMaster Carr. The factory pin is a 4mm straight bodied pin with one-(1) end already mushroomed for the 4.5mm hole in the hardened steel gear.
BURN-BROS 06-09-2011 10:05 AM
Honestly no. To be fair, there are plenty of other distributors that utilize rollpins. Bosch however was not one of them. Personally I would not want to be the guy who installed one for a customer that walked out.
DRACO A5OG 06-09-2011 01:57 PM
Better Safe then Sorry :eek:
Do you have a website?
BURN-BROS 06-09-2011 02:55 PM
Sorry, no website yet...it's on the to do list! Give me a call if you have any questions.
DRACO A5OG 06-09-2011 03:06 PM
Roger That, maybe I will stop by when I'm up there showing properties :D and bring my back up dizzy.
BURN-BROS 06-09-2011 05:42 PM
Let me know,
We had the Rothmans 962C at the shop a couple of weeks ago...maybe you'll get lucky and time your visit right. ;)
