Manual door lock- knob problem- 84 Carrera
Hello Everyone,
Just having a simple problem and i know someone here has the solution.
My doors won't lock or unlock because the lock knobs are too tight. If i take off the knobs they work fine. I can tell the metal rod isn't straight enought and that's why it's not working. Is there some type of guide to keep it straight ?
Thanks Tay
Old 06-07-2011, 07:43 AM
anyone?
Old 06-07-2011, 11:49 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Are attempting this with the door open or closed?
'85 Carrera Targa
PCA/POC
Old 06-07-2011, 12:02 PM
crustychief's Avatar
Do you have the correct washer under the knob?
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 06-07-2011, 12:10 PM
nkotselas's Avatar
Doors have to be completely closed, iv'e had this problem and it just takes me some twists from inside and outside with the key to open it up
doesn't matter if the doors are open or closed , it's the same problem there is too much friction on the knob. it wants to pop off the plastic circle guide.
Crustychief- which washer are you referring to ? If it's the plastic one one the outside that the knob goes through then yes.
Old 06-07-2011, 12:21 PM
There is a guide between the door panel and the door.
If your door is open it won't lock. My 79 wont anyway.
Old 06-07-2011, 12:27 PM
ya that's there. The prob is the same if door is closed. As soon as i take off the little plastic caps up top everything is fine. It's just the rod that comes out at an angle. You think it would help if i changed the guide bushing ?
Old 06-07-2011, 12:30 PM
DRACO A5OG's Avatar
That is odd, those guides tend to pop off if you slam the door but will still allow the mechanism to operate. Strange.
'85 Carrera Targa
PCA/POC
Old 06-07-2011, 12:32 PM
i know, it's really wierd. It's the knob hitting the bushing that's the issue. I'm going to try some silicon grease and if that doesn't work maybe some new guide bushings i think. I just wanted to see if anyone else ever had that issue.
Old 06-07-2011, 12:34 PM
DRACO A5OG's Avatar
PM me your email address, I will send you a PAG manual on sealing the 911
'85 Carrera Targa
PCA/POC
Old 06-07-2011, 12:36 PM
Here is a diagram
Are you talking about number 14 in the picture or number 1?
Old 06-07-2011, 12:39 PM
. I'm talking about number 1. It's hitting the washer guide at an angle and not popping out. I unscrew number 1 and remove and everything works perfectly .
Old 06-07-2011, 12:42 PM
Lol, it's royally annoying. If #1 was smaller there would be no issue, i'm thinking about buying the rennline alluminum pins. hopefulyl they're a tad bit narrower.
Old 06-07-2011, 12:43 PM
DRACO A5OG's Avatar
Oh poop, this is a public site, remove your email address!
OK, unscrew the #1 so it will protude a bit then it should guide threw fine.
'85 Carrera Targa
PCA/POC
Old 06-07-2011, 12:46 PM
I thought you were talking about number 14. I hope the diagram page from the manual helps. I redid my window seals and had the door panel off a couple of other times and did not experience the problem you are. Sorry I couldn't help.
Old 06-07-2011, 12:48 PM
Turn the lock buttons counterclockwise enough turns so that when the door is locked, the top of the button is slightly ABOVE the ring (you call it a washer, I think).
So the top of the button is a tad proud of the door top when it is locked.
Counterclockwise raises the button.
Fixed mine.
Old 06-07-2011, 12:49 PM
DRACO A5OG's Avatar
Yeap it may be the wrong #1 or wrong ID trim ( you called washer ), get the proper guide or end cap. If on a budget open up the trim to fit the OD of the end cap/knob
'85 Carrera Targa
PCA/POC
Old 06-07-2011, 12:52 PM
