remove a sunroof ? can it be done?
Hi Guys
Can you remove a sunroof, on an Early 911? Is it a matter of welding it in? Anyone with experience with this? Thank You Joe |
I have seen some threads on this. Do a search on "sunroof delete".
Kipp 1987 Black 911 3.2 Carrera Coupe 1999 Green Mazda MX5 (SOLD) |
RETIRED
Yups....either cut a blank from a beater for the proper curve or fab your own (more work). Lots of tall and/or racers have done it.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
yes, and I think the karmahn ghia roofline works for a blank...might be cheaper.
The metal needs a dual curve so it will match and wont flop around. Rich |
Some people have welded the sunroof in to the hole, others have replaced the whole roof section and still others have purchased a flanged panel from chris_seven. There are several threads on this subject you might want to try a search
who is chris_seven??
Slippery Slope Victim
Use the search. There is plenty of info here.
MikeČ 1985 M491 |
