Chris Lovell's Avatar
Engine mounted heat blower dead
My '88 Cab electric blower (mounted above the engine) has stopped working. I checked the possible fuses in the front trunk and they seem okay. Also pulled the fan-blower and tested that on a 12v source and that works fine as well. Then I tested the wire delivering power to the blower and that connector is dead (ignition in full power setting and heat levers up).
Can anyone tell me if there are other fuses (passenger footwell or engine compartment) which are worthy of checking? I also have this nasty feeling about mice in the car again. Anyway, I'll check everything before I trace the wiring for rodent incursion.
Thanks,
CL
CWL
'88 Carrera Cab
Old 05-22-2011, 07:03 PM
sub. I think mine is dead also
Old 05-22-2011, 07:25 PM
Member 911 Anonymous
DRACO A5OG's Avatar
I think your year has fuses at the foot blower up in the cab
'85 Carrera Targa
PCA/POC
Old 05-22-2011, 07:30 PM
Eschews Obfuscation
dhagood's Avatar
draco, i think this is true as well, but the rear blower is a different beast.
have you checked the heater blower relay on the left side of the engine bay under the plastic shield? if that goes out, none of the heat blowers will operate.
Old 05-22-2011, 09:04 PM
DRACO A5OG's Avatar
Before the heater went out, did you smell a plastic burning smell? that would be the foot blower fuse.
Dhagood, I agree the engine bay relay is a nightmare if it goes out.
'85 Carrera Targa
PCA/POC
Old 05-23-2011, 03:09 AM
aj88cab's Avatar
The fuse (25A) for the engine compartment blower fan is on the electrical panel in the engine compartment (under the palstic cover on left side), the previously mentioned control relay is there too. Thge blower fuse is on a 3-fuse block that also includes control power for the blower control relay and the rear window defroster if equiped (your's is a cab like mine and will not have the defroster circuit).
Check continuity from the blower connector to pins 5/6 on the control relay connector.
Also check that the circuit & contacts on the red levers are working properly (12v at pin 9 on the control relay connector with lever up/ingnition in ON position).
If the above check out OK, then it is probably a bad control relay unit.
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 05-23-2011, 06:38 AM
I wish I had a simple single line drawing of the power and controls for all the electrical fans with notes for where each component is found. I started one by looking at Bentley but gave up. Anyone have one they or another made?
Old 05-23-2011, 07:16 AM
Andrew,
This is very good to know. I have definitely not looked into the electrical block in the engine bay. I will do so soon. I will check the 25A fuse and test the block for power and continuity. I will let you know what I find. I am hopeful the Bentley will give some further specifics on which control relay is of interest etc.
Thanks,
Chris
CWL
'88 Carrera Cab
aj88cab's Avatar
Chris
The blower control relay looks like this, most likely the 25A version on the left:
And is located here mounted in the (empty) center position. See also the fuse locations.
Pull the relay and make all the above tests at that connector.
The easist (only?) way to test the relay is if you can borrow a known good relay from a fellow Carrera owner and try it in your car, if the fan runs, your relay is bad...not exactly high tech, but it works
Good luck,
Andrew
Old 05-23-2011, 08:09 AM
Just how cool are those pictures!! Thanks so much Andrew. I happen to have another 911 which is tracked and therefore this relay will be available. And just my opinion but ... I think this particular fuse block is so outdated looking, it could be from a 1958 VW beetle. Probably was... anyway, many thanks.
Chris
CWL
'88 Carrera Cab
Old 05-23-2011, 08:43 AM
Andrew and all, the engine compartment fuses are fine. Pins 5/6 have continuity to the positive connector at the blower motor. Pin 9 does not have 12V with the ignition fully on. So, I am now headed to the interior heat lever switches. Once I figure out how to get to them. :-)
CWL
'88 Carrera Cab
Old 05-25-2011, 02:49 PM
Monza_dh's Avatar
why not do the infamous heater bypass route? do a search and you find many links for removing the blower and just using your footwell blowers. it will look like this:
$35 and a six pack to my name.....
'88 Diamond Blue Carrera CE 3.4-SOLD
Old 05-25-2011, 07:09 PM
Monza, this sounds like a really good idea and for $35 and a six pack of PBR, a bargain. My problem is the footwell blowers also do not work. I was thinking those will only work if the engine blower is working. Is there a work around to enable the footwell blowers only?
CWL
'88 Carrera Cab
Old 06-05-2011, 07:18 PM
wdfifteen's Avatar
I am very interested in hearing an answer to this. My footwell blowers don't get power to their fuses under any circumstances. If I could find a way to make the floor levers power the blowers I'd get rid of my engine compartment blower. Right now it's the only one that works.
Old 06-05-2011, 07:23 PM
bump. Patrick and I are interested.
CWL
'88 Carrera Cab
Old 06-08-2011, 12:27 PM
aj88cab's Avatar
Grab a beer (or two) and start reading
Start with this to get an overall idea how the control circuit works:
Heater Control Circuit
And this:
http://members.rennlist.com/imcarthur/911autoheat.htm
Then this one that discusses a "jumper mod" that will delete the engine blower and allow you to use the footwell blowers (read to end for latest mod variation that eliminates the FW blowers running all the time):
Carrera - Removing Engine Compartment Heater Blower
There are several other threads that address this item too. Just search "engine blower" or Jumper mod", etc.
Old 06-08-2011, 12:56 PM
Man o man, Andrew to the rescue again!!! Thanks. I think the beer is the best idea.
CWL
'88 Carrera Cab
Old 06-08-2011, 02:17 PM
Andrew and all,
Even though Pin 9 did not have elec power with the heat levers up, it turns out the relay was the problem. I tested the heat lever microswitch for proper operation and it is fine. I then swapped the relay with 86 911 and the heater blower works fine. So, thanks for the help and guidance. Now on to the next project.
Anyone know a good source for the 918 618 153 00 relay?
CL
CWL
'88 Carrera Cab
Old 06-11-2011, 09:36 AM
