Will later rear alu trailing arms fit a 72/73 911?
Hello there,
Got a bit of a worry,well actually not me but a friend of mine is looking to put rear alu swing (trailing) arms think they're 1976 's (so later type), the aluminium type onto his 911 S year 1972/1973 WILL these fit? Will the wheel and shocks face any problems? Will the wheel be corectely alligned in the rear wings? In other words are they different in lenght and on... Go on and give me your thoughts on this.... ![]() THKS |
they fit ok. i recall having to shorten the mounting for the lower shock bolt 3/4" or thereabouts. used a sawzall.
Max Sluiter
They fit much better on a 72 or 73 than a 70 or 71. I think they are a direct bolt on for 72 and 73 because didn't the 74 get them from the factory? There were no significant geometry changes in the rear chassis between those years.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Here are mine.
76 arms on a 73 tub. Direct bolt-up. First picture is at full droop. Second picture is at simulated ride height while playing around with suspension travel/wheel fitment. The shock dust cover is off in the second picture because I was measuring the travel. They fit either way. ![]()
Joe Frantz 73 911 T |
maybe it was an earlier car that needed the shock mountings shortened.
Max Sluiter
70-71 at least need mods. You were probably thinking of that.
Under the radar
I don't think there is a definate cutoff for when Porsche went to the longer shocks in the rear. I've seen a 72 that had the longer shocks, and a friend has an original 73 with the shorter older style shocks. Both had steel banana arms. So in your case you will just have see if mods are required.
Certainly aluminum on a 74...would expect it would be a direct swap to a '73.
Under the radar
Here is a link to Sherwood's (911pcars) Excellence Magazine article on the Rennlist site.
This article, along with the additional links included on page 5, contain just about anything you need to know about aluminum trailing arm compatibility and installation. UpgradeAlloyControlArms
MANY THANKS,
![]() He was very pleased with the results you send...
Joe's link to Sherwood's article was pretty comprehensive. Amazing what a resource that this site...and Pelican's can be.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
