Where can I find these push connectors?
I am trying to find out where I can buy both large and small right angle push connectors for the engine harness (see pic). The standard connector width, shown on the bottom, is 6.3 mm and the wide connector on top is about 8 mm. There were several of these connectors on the 78-83 SC engine harness and Im sure they were used for other years as well. The wide connector is hard to find and they are used for the thermo switch and one of the temp sensors to the right of the fan housing.
http://forums.pelicanparts.com/uploa...1307898920.jpg Thanks Andy |
Thanks kerthunk. I am looking into this and waiting on a reply to see if they carry the double crimp type connection to the wire.
Thanks stlrj.
connectors
Wurth USA has the german connectors and the tool to crimp that style of non insulated ends, with heat shrink its just like factory
Mike Bruns |
Al and Mike, thanks. Im part way there. Both Eagle Day and Wurth carry the 6.3 mm width, but they don't seem to have the wide 8 mm flag connector. I have contacted Eagle Day in the past and I think I will call Wurth now. Very helpful though guys and I appreciate it.
Andy |
| All times are GMT -8. The time now is 06:08 AM. |
