Where can I find these push connectors?
I am trying to find out where I can buy both large and small right angle push connectors for the engine harness (see pic). The standard connector width, shown on the bottom, is 6.3 mm and the wide connector on top is about 8 mm. There were several of these connectors on the 78-83 SC engine harness and Im sure they were used for other years as well. The wide connector is hard to find and they are used for the thermo switch and one of the temp sensors to the right of the fan housing.
Andy
83 SC
Old 06-12-2011, 10:17 AM
Chief Head Scratcher
kerthunk's Avatar
McMaster-Carr has them. Look for "Flag Quick-Disconnect Terminals".
McMaster-Carr
John Morris
'79 911SC
Old 06-12-2011, 10:41 AM
Thanks kerthunk. I am looking into this and waiting on a reply to see if they carry the double crimp type connection to the wire.
83 SC
Old 06-12-2011, 10:13 PM
Don't forget you'll also need the special crimp tool with the tit on one side to curl the ends back down on the wire.
Old 06-13-2011, 03:58 AM
Thanks stlrj.
83 SC
Old 06-13-2011, 06:05 AM
al lkosmal's Avatar
Eagle Day carries these.
Right Angle female blade connector and rubber sleeve
regards,
Al
RGruppe #669
http://www.x-faktory.com/
Old 06-13-2011, 06:12 AM
connectors
Wurth USA has the german connectors and the tool to crimp that style of non insulated ends, with heat shrink its just like factory
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 06-13-2011, 06:16 AM
Al and Mike, thanks. Im part way there. Both Eagle Day and Wurth carry the 6.3 mm width, but they don't seem to have the wide 8 mm flag connector. I have contacted Eagle Day in the past and I think I will call Wurth now. Very helpful though guys and I appreciate it.
Andy
83 SC
Old 06-13-2011, 07:01 AM
