headlight question
when I pull the headlight switch out the parking lights work but headlights don't come on. If I flash bright lights using steering column arm those work. I pulled the headlight switch and cleaned contacts. Any ideas on where to start? Replace the dash switch? (it is expensive). Thanks, this forum rocks!
silver 991S
red '86 911 - resto-mod in progress
1974 Ford 3000 diesel
too many motorcycles sold too list -
Old 03-14-2018, 05:19 PM
Car running.
Old 03-14-2018, 05:50 PM
Banned but not out, yet..
RSBob's Avatar
If the car is running and no headlights but only high beams you have my exact problem. It was cured by installing a new stalk switch/lever.
Old 03-14-2018, 09:04 PM
Air Cooled
Craig_D's Avatar
It should be noted that, unless you've installed headlight relays, the full power for the headlights runs through the stalk. Often times, this problem can be cured by installing the headlight relays, which bypasses the stalk for power, and only uses the stalk to trigger the relays, and takes the power load off of the stalk.
I had a similar issue where the high beams wouldn't work every time, so I installed the headlight relays and cured the problem. Bonus is that you get brighter headlights because that power is going directly from the battery to the relays, and then to the headlights (in place of the long journey through the stalk).
I bought my relays from the host.
Hope that helps.
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat"
'99 Honda VFR800Fi, '98 Honda SuperHawk
'88 Honda Hawk GT, '77 Honda CB750K Cafe
'69 Honda CL350
Old 03-14-2018, 10:08 PM
Whether the car is running or not doesn't make a difference. I will try the relays first. Thanks for the help.
silver 991S
Old 03-15-2018, 06:32 AM
Flojo's Avatar
yes, a common problem. had the same issue.
the levers inside heats up and deforms so contacts are mismatched.
its due the oem-wireing with no relay.
the inside of this unit is the unrepareable culprit:
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 03-15-2018, 07:04 AM
al lkosmal's Avatar
headlights
turn signal switch quick fix pictures
RGruppe #669
http://www.x-faktory.com/
Old 03-15-2018, 08:25 AM
universeman's Avatar
Flojo it's not unrepairable, it's actually repairable with a tiny screwdriver and a little patience. Al's post gives you all the info you need. This does sound consistent with the symptom OP is seeing.
Jason - Austin, TX
82 911 SC targa (gone, but not forgotten)
92 968 coupe
Old 03-15-2018, 10:28 AM
