Brorag
tie rod removal
is there a plan B if you don't have a tie rod removal tool?
Fleabit peanut monkey
Buy a cheap set of wrenches (e.g., Harbor Freight) and grind the largest one to the correct size (and thickness)
drive to your FLAPS and buy or borrow one, they are only $10 or so.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
Member 911 Anonymous
National FLAPS will rent the Pickle Fork for free.
Make sure you place piece of plastic,like a milk carton between the tool and rubber to keep it from tearing. Not my idea but an ingenious Pelican, sorry can't place the call sign. Jim
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
