CIS testing - Dwell meter
I have a Sears Engine Analyzer (Model 161.216300) with red, black and green connectors plus an RPM plate. It also has a Range selector Dwell ( 0-100rpm) or Points( 0-6000 rpm, Low voltage). A Function Selector dial for Volts, Amps, Dwell/Points, 4 cyl, 6cyl, 8cyl. This unit is old, but new in the box.
Red connector to the rear fuse panel Black connector to ground Geen to the pin connected to the Green/w white on the test plug Range selector set to Dwell Function Selector set to 4 cyl. I'm not getting any of the test values I would expect. With the Range selector set to Dwell, the needle goes to around 10 on the 4 cyl scale With the Range selector set to Points, the needle goes to around 30 on the 4 cyl scale. Black connector to test plug green w/ white, the meter is pegged with the range selector set to Dwell. Is the setup wrong or is the unit faulty? Thanks in Advance, Guy |
On my meter it's black to ground, and red to the green/white on the diag plug in the engine bay.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
5String
Thanks in advance - Jon (Oh, and I don't mean to hijack this thread.)
5String Tell not a soul that you have seen me; breathe not a word of what I say.... The Northwest Files |
Guy,
Your hook up is correct, make sure the green alligator clip is not touching any of the other pins. What does it read if you turn the knob to volts ? If the meter is unknown, I would try it on a points ignition car to see if the dwell function works. Do you have a good O2 sensor and can you tell if the system is going into closed loop ? The idle should fluctuate when hot and the switch on the right timing chain cover is open.
Paul |
Fleabit peanut monkey
For 5String43. It may be buried under the relay panel.
Success !!
![]() ![]() On this model setting the Range selector to Dwell and the Function Selector to Dwell/Points works using the 4 cyl scale on the meter. Scott R: Black to the Pin - Green w/white wire is WRONG. Sorry, you're correct. Black to ground, Red to the fuse panel and green connector to pin for this model. I didn't try Red to Pin. Paul: Thanks for getting me to play with the switches. Yes, I going to closed loop which I see with the dwell meter plus looking at the voltage from the oxygen sensor. Tested the 15 degree switch yesterday so I know that is good. Your input into the CIS subject across the board has been most helpful!!! I've been following a number of the CIS threads in order to cleanup a rough idle at start up. Fuel pressures are good, WUR is good, AAV is good, tested vacuum with carb cleaner. Didn't find anything, but I'm still not sure. FV has voltage, hums and vibrates although it doesn't kick in right away. I replaced the O2 sensor when I replaced a chain tensioner. Retimed and then things started to get worse. I suspect the PO may have had done something to the mixture to compensate. The car is a 83 911SC |
5String
Bob, thanks very much. It's right where you predicted it would be. But I find when I look at my old dwell meter that its leads are two in number - red and black. I imagine this renders it unusable for this function, no?
Thanks-Jon
5String Tell not a soul that you have seen me; breathe not a word of what I say.... The Northwest Files Last edited by 5String43; 06-14-2011 at 04:59 PM.. |
CIS troubleshooting..........
wichitaguy,
Check your ignition timing, fuel pressures, and air leaks. Adjusting the fuel mixture without verifying the integrity of the vacuum system (air leak) is the most common mistake by most DIY'ers. Here is an example of an engine the owner claimed not to find an air leak using a carb cleaner. ![]() ![]() CIS is very sensitive to air leak/s causing the mixture to go lean. So making the mixture richer is a band-aid solution instead of fixing the root cause of the problem. Tony Last edited by boyt911sc; 06-14-2011 at 06:55 PM.. |
Tony: can you send me your procedures for finding vacuum leaks? I PM'd you, but never heard back. Hope all is well.
Please accept my apology......
Guy, I have already composed the procedure (air leak detection for CIS) with pictures for you and a couple of members last week but I forgot to forward them. I'll retrieve the instruction and forward it to you ASAP. Tony |
Romel
Hi Tony and team, it's been great reading through your posts. I'm a newbie and a first time proud owner of a beautiful 1983 911 sc. I'm looking forward to provide the best care I can.
Would it be possible for you to please share your leak detection procedure with the rest of us or via email. Reason being: insert key into ignition turn to position 2, it makes a buzzzzing sound (coming from the dash not sure why), starts car ( starts up right away), but them stutter during idle. I have to keep feet on accelerator of 5 mins before I can drive. The car is kept in temp control garage around 72 degrees. Trying to understand reason for this action. Thus hoping to identify leaks. Thank you Romel |
Tony, could I get a copy of those test instructions?
Lorne M.
83 SC |
Tony,
I'd love to see a copy as well if possible. I'm sure alot of people would find it usefull. Maybe you should see about making a it tech article on the site.
Matt. 83 911SC 85.5 944 NA - Sold |
Air leak test procedure.........
Romel/Lorne/Matt/ et al,
I had demonstrated the procedure several times in my previous posts. The test takes about a minute and you're done. Since a lot of CIS owners wanted to have the procedure documented, I'll prepare one for the community. Once I located the culprit for the battery drain in my son's '87 Carrera, I'll have the procedure posted very soon. Hope this helps others. Tony |
too many projects 1983 sc
I had one like that (different brand) and could never get it to work. A couple other people had the same issue with it. I was never able to figure out why, but I think you may be right.
I ended up getting a craftsman digital multimeter that also reads duty cycle. Works great. The only issue is that it reads the positive slope and lambda works on negative slope. So I have to subtract my results from 100 to get the correct reading.
when you use the digital ( cost?) is it hooked up the same way...only difference is the subtraction thing? ben |
Product The red hooks up to the green plug, and the black hooks up to a ground. Some people say the analog ones are better because its easier to see a needle swinging than a digital read out. I'm okay with it.
We need to get to the bottom of this so get me the data. You have been struggling with this for weeks. Take it off line with me if you wish but there is something wrong in the basics. |
