-   -   B&B Heat Exchangers with other than B&B muffler? (http://forums.pelicanparts.com/porsche-911-technical-forum/614127-b-b-heat-exchangers-other-than-b-b-muffler.html)
Joeaksa 06-15-2011 06:45 AM
Anyone use B&B heat exchangers but not use their mufflers?
I keep hearing that their muffler's are crap, especially the early ones that drone and welds break.
I have a 3.6 in the car and SSI's right now but am told by several people that the SSI is just too small a primary tubing for a 3.6 and need to go bigger.
The SSI's I have are with a Dankse stainless "banana" muffler and its just about right, but the "Two bolt" flanges will not bolt up to the "three bolt" flanges on the B&B HE's.
Anyone "been there and done that" with these parts?
Thx,
Joe
Bill Verburg 06-15-2011 07:44 AM
Thx,
Joe
The SSI's are definitely too small, B&B headers will wake the car up.
I used a Flowmaster but it's loud.
GaryR recently adapted a Magnaflo #12568 to his and it's LimeRock legal, which is saying a lot.
Gary R's
http://forums.pelicanparts.com/uploa...1301711102.jpg
Mine, but painted black after this shot was taken
http://forums.pelicanparts.com/uploa...1308148871.jpg
If you can find a good welder you could probably move the inlets on the Dansk banana to accept the B&B spacing, flanges can be bought to match
JeremyD 06-15-2011 08:40 AM
I had a magnaflow on mine - that was loud! - then an MK - then I went to 993 heat exchangers with a MK single out (on the 3.4 cab)
With this car (that's in the process of getting a 3.6) I plan on installing this muffler that shakinjoe found - (I guess from a mercedes)
http://forums.pelicanparts.com/uploa...1308152355.jpg
not too far off
http://forums.pelicanparts.com/uploa...1308152383.jpg
http://forums.pelicanparts.com/uploa...1308152393.jpg
Joe Bob 06-15-2011 09:58 AM
I used 993 HEs, modded flanges to fit the 964 heads....custom muff and cat.
http://forums.pelicanparts.com/uploa...1298470124.jpg
gtc 06-15-2011 10:11 AM
The only things worse than B&B mufflers are the makeshift B&B heater boxes. I'd go with some big George's if you can get by without heat.
Tom '74 911 06-15-2011 12:22 PM
I have a Magnaflow 11385 (4"x14" case w/2.25" in/outlets) on my 3.6L w/Fabspeed headers w/heat. Between 1.5-3K rpm, it drones like a mother. Above 3K rpm, it's quiet(er). I'm looking at options to try to quiet it down a bit.
GaryR's Magnaflow 12568 (5"x22" case w/2.5" in/outlets) is bigger and thus probably quieter. I may look at this as an option.
I have a nice stainless Dansk banana muffler from my 2.7L engine and making it fit my Fabspeed headers would be a BIG task I think. The outlets from the headers are so far apart, even if you redid the muffler inlets, it would take some serious head scratching to mate them together.
Tom
KTL 06-15-2011 03:05 PM
We used a Dynomax on a 3.6 conversion I participated in. We used the "flows all directions" dual in dual out muffler. Dynomax® Performance Exhaust | Mufflers | Super Turbo™ Mufflers Sounded nice and not too offensive.
The Fabspeed/Flowmaster that was originally on it was indeed LOUD.
Gary's installation looks like a very nice one- the O2 bungs and flange clamps are a clean install
Kevin Stewart 06-15-2011 06:14 PM
I use their headers and muffler, the 4 inch tips set alarms off reduced the tail pipes to 2.25 and i am really please with the sound, i can see the mufflers having problems if the bands get loose, Kevin
Joeaksa 06-15-2011 06:15 PM
Cannot live without heat. Some of my trips are up in the mountains so need the heat to work.
Bill,
Thanks much and your post gave me an idea. I live right around the corner from B&B (like 2 miles away) and may head over by their place and see if they would sell me just a set of flanges. Then I could use anything or build an adapter to use various mufflers.
JoeBob, I do not need a cat here, the car is registered in a small town where the smog test is not done, but I do like your system.
Great ideas guys, thanks much!
Joe
KTL 06-16-2011 06:50 AM
A contributing factor to their muffler failures is the flimsy bracket they use to support the muffler. It's a nicely designed bracket in terms of fitment. But it's not sturdy enough. The bracket needs to be supported/triangulated with some gussets to keep it from flexing. The flexing is what causes the muffler end casing to crack and that's why B&B puts the supports on the muffler inlet pipes. What they should be doing is putting the supports on the muffler bracket!
Joe Bob 06-16-2011 09:09 AM
The cat is part of the sound suppression....the spiral type muff after it gives it a nice burble.
Joe Bob 06-16-2011 09:36 AM
BTW, Joe....did you see the thread on the converted banana sport muff with 993 HEs?
I have an extra sport muff sitting in the garage that can be converted.
If you don't like the sound, send it back. You'll just need a couple of 90s and the flanges. If you use 993 HEs, they exit facing eah other unlike the B&B and older/early style 911 equal length HEs.
Just pay shipping.....
Joe Bob 06-16-2011 10:36 AM
http://forums.pelicanparts.com/porsche-911-technical-forum/600463-carrera-muffler-adapted-993-engine.html
Found the link....;)
Quicksilver 06-16-2011 06:33 PM
not too far off
What is this muffler off of? I want to check this out.
I have the Dynomax 17725 on my B&B and it was much louder then I wanted. I plugged one of the outlets and it is real respectable until it hits 2800 and then it sounds like a motorcycle taking off. (Pretty cool but too conspicuous for me). I ended up putting a glasspack between the muffler and the tip and that makes it liveable but still very aggressive at full throttle above 2800.
cgarr 06-16-2011 06:50 PM
Here is one Ben built for the B&B headers, its a bit loud and I think he only made two of them.
http://i30.photobucket.com/albums/c3...1/e4ed622c.jpg
JeremyD 06-16-2011 07:03 PM
I have no idea - and yes, - I had the 2nd B & B muffler that Ben made.
Joeaksa 06-17-2011 03:58 PM
Was wondering if Ben had played around with this at all.
I like loud but my neighbors do not so thats not going to work.
cgarr 06-17-2011 04:54 PM
This muffler guarantees a letter from the neighbors!
http://forums.pelicanparts.com/porsche-911-technical-forum/602748-ticked-off-neighbors-about-my-porsche.html
