speaker removal
OK. I have searched and not found. I have looked through the books I recently purchased. How do you remove the stupid speakers. I have 6.5 in rear and 5.25 in door (83 cabriolet). I am afraid to pry the grills to hard, just in case something is different. They are JB Audio units.
I assume you mean you have JB Audio units in you car and you want to remove and replace them.
I don't know about JB, but I just replaced all the factory Blaupunkt speakers in my '87 Carrera and each one was held in by 4 phillips-head sheet-metal screws which were plainly visible and accessible. If you don't see screw heads on your speaker grills, I would guess the grills just snap on and the screws are hidden beneath. However, don't send me the bill if there is something more sinister at play here.
Silver '87 Targa Last edited by Spin City; 11-02-2006 at 04:51 PM.. |
I have Boston Acoustics in the doors, and the grilles come off by twistin and then pulling. There are tabs that seat into the speakers.
Brian 84 928S Euro |
whoops! I mean MB Quart....
They are sure tight on the there. I will try twist and then pull maybe. Never had any like that before. Just seem awful tight!
Shane - 1984 928S |
Are you unhappy with The Quart or are they blown? Grill should pull out with firm pressure. Phillip head screws will be exposed underneath. If the speakers are not blown Quart makes a nice driver.
76 911/2.7/SSI/2in 1out/tensioners/Ice Green Targa 01 Suburban 02 Jeep Liberty WillsWings Eagle "As I hug the mountain tops in my hang glider, the only distraction Is looking below at the roads I will hug with my 911 " |
How do I remove the factory speaker on my 91 Carrera 2? I got the tweeter out but I could not get the 5.25" speaker out. Any help is appreciated.
1970 Morris Cooper S, 1973 Mini Clubman GT, 2008 BMW 135i Coupe, 2008 BMW 128i Cabriolet, 1995 BMW M3, 2016 Mazda Miata |
