-   -   Electrical parameters of components on a C3.2 engine (http://forums.pelicanparts.com/porsche-911-technical-forum/614300-electrical-parameters-components-c3-2-engine.html)
Tippy 06-16-2011 05:09 AM
Does anyone have a list of parameters regarding ohms, volts, etc., for a C3.2's engine sensors, electrical components, etc.?
I am having to go into warp mode on diagnosing my low-RPM sputtering problem and nothing so far has been definitive.
TIA SmileWavy
Tippy 06-16-2011 08:49 AM
--crickets--..........--tumbleweeds--
r_towle 06-16-2011 09:00 AM
which sensors?
Describe the problem.
Rich
Tippy 06-16-2011 09:21 AM
Originally Posted by r_towle (Post 6083094)
which sensors?
Rich
http://forums.pelicanparts.com/porsche-911-technical-forum/613514-87-c3-2l-bucking-when-taking-off-question.html
I checked the CHT and got 1.082k ohms at cold and a tad higher at hot. I think this maybe it but not 100%. The "track" on the AFS has a very light groove, not as deep as I have seen others.
crustychief 06-16-2011 09:29 AM
speed and reference sensors;
between terminals 1&2 @77degrees F 960 ohms +- 96 ohms
between terminals 1&3 >100000 ohms
between terminals 2&3 >100000 ohms
Rotor
center to tip of rotor 1K ohms
Fuel injector harness 2 - 3 ohms
or... this...
http://forums.pelicanparts.com/uploa...1308241763.jpg
crustychief 06-16-2011 09:30 AM
It is all in the Bentley manual. A wise investment for do it yourselfers.
Tippy 06-16-2011 09:42 AM
Rotor
or... this...
Thanks! That's what I am looking for.
You know, I actually have the manuals electronically. I didn't even think to look......
http://forums.pelicanparts.com/suppo...eys/paddel.gif
Flat Six 06-16-2011 10:02 AM
Depending on what 'cold' means in your area (105 F ambient in San Antonio? :) ), 1.082K ohms seems a little high. More importantly, though, CHTS resistance should decrease as temp increases. I'd re-check to make doubly sure, but sounds like replacement is in your near future.
HTH
Tippy 06-16-2011 10:36 AM
HTH
Yes! Ambient or cold would be about 101 degrees yesterday. I ran the car about 5 minutes (lugging I should say to get it to warm up and reveal the symptoms) and let it sit about 1-1.5 hours before I checked it warm. I wouldn't think the head got all the way to ambient again since my IC was a little warm to the touch.
dtxscott 06-16-2011 10:58 AM
What really matters is what the ECU sees. I would check the measurements at the ECU.
A corroded connector can skew the signals significantly.
Tippy 06-16-2011 11:19 AM
Very true, although putting ohms (which involves voltage output of the multimeter) through a comptuter terminal can be terminal for the computer, correct?
dtxscott 06-17-2011 01:13 PM
It is definitely not desirable.
The correct plan would be to remove the connector on the ECU and take a resistance reading through the connector. This is what the ECU would "see".
