Chain fence eating turbo
Question Electrical parameters of components on a C3.2 engine
Does anyone have a list of parameters regarding ohms, volts, etc., for a C3.2's engine sensors, electrical components, etc.?
I am having to go into warp mode on diagnosing my low-RPM sputtering problem and nothing so far has been definitive.
TIA
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 06-16-2011, 05:09 AM
--crickets--..........--tumbleweeds--
Old 06-16-2011, 08:49 AM
r_towle's Avatar
which sensors?
Describe the problem.
Rich
Old 06-16-2011, 09:00 AM
Originally Posted by r_towle View Post
which sensors?
Rich
'87 C3.2L bucking when taking off question
I checked the CHT and got 1.082k ohms at cold and a tad higher at hot. I think this maybe it but not 100%. The "track" on the AFS has a very light groove, not as deep as I have seen others.
Old 06-16-2011, 09:21 AM
crustychief's Avatar
speed and reference sensors;
between terminals 1&2 @77degrees F 960 ohms +- 96 ohms
between terminals 1&3 >100000 ohms
between terminals 2&3 >100000 ohms
Rotor
center to tip of rotor 1K ohms
Fuel injector harness 2 - 3 ohms
or... this...
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 06-16-2011, 09:29 AM
It is all in the Bentley manual. A wise investment for do it yourselfers.
Old 06-16-2011, 09:30 AM
Rotor
or... this...
Thanks! That's what I am looking for.
You know, I actually have the manuals electronically. I didn't even think to look......
Old 06-16-2011, 09:42 AM
Flat Six
Flat Six's Avatar
Depending on what 'cold' means in your area (105 F ambient in San Antonio? ), 1.082K ohms seems a little high. More importantly, though, CHTS resistance should decrease as temp increases. I'd re-check to make doubly sure, but sounds like replacement is in your near future.
HTH
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 06-16-2011, 10:02 AM
HTH
Yes! Ambient or cold would be about 101 degrees yesterday. I ran the car about 5 minutes (lugging I should say to get it to warm up and reveal the symptoms) and let it sit about 1-1.5 hours before I checked it warm. I wouldn't think the head got all the way to ambient again since my IC was a little warm to the touch.
Old 06-16-2011, 10:36 AM
Easily Confused
dtxscott's Avatar
What really matters is what the ECU sees. I would check the measurements at the ECU.
A corroded connector can skew the signals significantly.
Scott C.
'08 Cayenne GTS 6MT : '89 Targa GP White/Black - "Oliver's Car" : '11 Mitsu Evo X : '08 Lexus IS350 F-Sport : '01 Toyota Sequoia : 1998 Yamaha V-max : 1979 BMW R65
Old 06-16-2011, 10:58 AM
Very true, although putting ohms (which involves voltage output of the multimeter) through a comptuter terminal can be terminal for the computer, correct?
Old 06-16-2011, 11:19 AM
Easily Confused
dtxscott's Avatar
It is definitely not desirable.
The correct plan would be to remove the connector on the ECU and take a resistance reading through the connector. This is what the ECU would "see".
Scott C.
Old 06-17-2011, 01:13 PM
