930 Fuel Gage Quantity Error
Hello all-
Let me start by saying I have tried to do a search of these forums to solve this problem, and have not found an answer, and/or I have not asked the Forum Search Genie the question in the right sequence of words..... I am on the road in my '77 930, having been forced to evacuate for the recent huge forest fires in Arizona over 2 weeks ago..... the fuel gage on the 930 has suddenly acting funny- it won't indicate over about 5/8 full tank when the tank is full. Tapping on the gage pilot style gets it to bounce to 3/4 momentarily, then it indicates 5/8 again. When the fuel quantity gets down to 5/8 and below, the gage operates normally..... I have: taken the fuel sender out and apart- the float slides easily, no crud/varnish anywhere, the slide wires and electrical contacts look good- no obvious problems.... Sprayed everything with carb cleaner... Checked the fuses- most are fresh, clean contacts w/o oxidation.... I have not: had the chance to pull the sender out again, take it apart, re-connect the fuel gage electrical plug and ground the sender, and then move the float to see if the gage needle moves with the movement.... So Electrical Gurus: does this sound like a gage or sender problem? anybody had something similar? thanks for the help..... Tim Alpine, Az. |
Member 911 Anonymous
Disconnect Battery then Pull the gauge carefully. Check if ground has a good contact, remove and polish both connector and spade if need.
If this does not help, dis-assemble and re-flow the joints. Next would be the sender unit. Search for re-furbing the sender unit. Last would be to replace sender unit.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
