OldTee's Avatar
Transmission question with pics
I bought a rebuilt txmn rather than have mine repaired. In preparing for the swap I ran into a little problem. The clutch release lever on my 79 transmission has a pin holding it onto the clutch release cross shaft. pic 1
note hole at end of scredriver. My cross shaft has a groove for the pin but the replacement transmission shaft does not. The replacement is from a 1983. The pin is not shown in PET and not referenced in Bentley (301-5).
pic two and three
I am planning to swap the crosshafts, still I wonder why the change. The older transmission clutch release lever is better secured on the 79 than the 83 and the question remains, which is best. I am filp flopping on the issue. Any advice from somebody who has done it before?
Old Tee
all 911s sold
Old 06-18-2008, 01:00 PM
it doesn't need the pin. later ones don't use it. you could always swap the shaft if you feel the need.
206 637 4071
Old 06-18-2008, 01:24 PM
OldTee's Avatar
Thanks, I'm trying not to feel the need.
Old Tee
all 911s sold
Old 06-18-2008, 01:33 PM
Peter Zimmermann's Avatar
Make sure that you put a nice thin coating of high-quality grease on the shaft before you slide the cross-arm (lever) on...
Keep the Shiny Side UP!
Pete Z.
Old 06-18-2008, 02:22 PM
Url Url is offline
Url's Avatar
Does anyone know if the rollpin can be punched out from both sides? I only have access to one side (due to Heat exchangers) and trying to tap it out from there but until now it won't move ... I just want to make sure it is not cone shaped and can be removed from both sides ...
Old 06-19-2011, 01:08 PM
it's a straight bore, so either side, but they're a bittch sometimes. a pointed air hammer bit helps get them moving.
206 637 4071
Old 06-19-2011, 01:25 PM
Url Url is offline
Url's Avatar
Thanks for the advice John!
Old 06-19-2011, 01:33 PM
