-   -   Help: SSI / Engine Tin Installation Problem (http://forums.pelicanparts.com/porsche-911-technical-forum/614798-help-ssi-engine-tin-installation-problem.html)
JJ 911SC 06-19-2011 05:19 AM
Start to put her back together.
I installed the tin around the engine (86 3.2) and went on to installed the SSI.
The one on the the driver (LH) side (pics showing engine upside down) definitely interferes with the SSI.
Anybody else encounter this (could not find it in any search result) and what is the solution, snip away?
Old HE
http://forums.pelicanparts.com/uploa...1308485048.jpg
http://forums.pelicanparts.com/uploa...1308485308.jpg
SSI
http://forums.pelicanparts.com/uploa...1308485463.jpg
http://forums.pelicanparts.com/uploa...1308485538.jpg
Geronimo '74 06-20-2011 12:12 AM
I'm bumping this since I have SSI's as well that i need to install.
Is there a difference between the later and earlier pieces of engine tin on that location?
j911brick 06-20-2011 02:43 AM
I had a similar problem on a MFI car.
yes, the earlier cars don't have tin that sticks out like that. Its usually flush with the back of the motor.
RoninLB 06-20-2011 06:03 AM
on my car i only had to pound the SSI edge up to fit
No big deal
http://forums.pelicanparts.com/uploa...1308574978.jpg
Shaun @ Tru6 06-20-2011 06:10 AM
This just happened to me with a pair of George's headers. The tin is important there due to the head temp sensor. I just rolled the tin up to accommodate the headers. Was fairly simple using a huge crescent wrench to grip and and form. Used a shop rag in between jaws and sheetmetal.
WIL84911 06-20-2011 07:27 AM
I guess an 84 tin is different..
Mine clears... and as mentioned you MIGHT need to pound one area on the SSI to clear the clutch spring..
http://forums.pelicanparts.com/uploa...1308579937.jpg
JJ 911SC 06-20-2011 05:03 PM
Shawn
Did you roll in inward or outward? Pics if available.
Cheers
JJ
Shaun @ Tru6 06-20-2011 06:16 PM
JJ, I rolled up if that makes sense. Just in from the car now, I'll take some pics tomorrow afternoon and post.
JJ 911SC 06-20-2011 07:09 PM
Thanks, it will help mentally :)
NewfieMZ3 06-20-2011 08:21 PM
JJ........just getting her put together I see. Good luck.......I'm in town in a few weeks.
JJ 911SC 06-20-2011 08:57 PM
Maybe I'll be on the road by then :rolleyes:
If not we'll have a few beers SmileWavy
Shaun @ Tru6 06-21-2011 04:44 AM
here you go.
http://forums.pelicanparts.com/uploa...1308656652.jpg
http://forums.pelicanparts.com/uploa...1308656668.jpg
http://forums.pelicanparts.com/uploa...1308656681.jpg
JJ 911SC 06-21-2011 05:56 AM
Shaun
Perfect. That is the way I pictured it.
On you 1st photo, does you oil line touch the engine (at 6 O'clock, around the transmission)?
Cheers
JJ
Shaun @ Tru6 06-21-2011 06:08 AM
Glad to help. The oil line does not touch at 6 o'clock, but the it does touch the cylinder sheet metal a tiny bit. I was told not to worry about it. It is coming off to have the rubber hose finished. We cut it down to meet up with custom high clearance oil lines.
