-   -   rust question (http://forums.pelicanparts.com/porsche-911-technical-forum/614856-rust-question.html)
ramonesfreak 06-19-2011 02:11 PM
rust question
found what looks like a small amount of rust at the edge of the right front fender where it meets the trim piece near the accordion.
is this is a common spot and what should i expect. should i deal with this somehow asap and how? i dont have the $ for professional help so i would have to tackle it myself i guess...
looks like a good spot (being at the edge of the metal) to have a rust issue as opposed to it being somewhere in the middle of the body
http://forums.pelicanparts.com/uploa...1308517767.jpg
j911brick 06-19-2011 02:32 PM
Looks like rust started because of a previous repair. If you don't have talent and resources for painting then you might want to leave it alone. Your going to gave to clean the area at least 1/4" up from the seal and at le3ast get a good quality primer/sealer on it. You can clean it with sanding but sand blasting would be much better and last longer.
