Liberal Prawn
ack - more help needed - night vision impaired
When driving Welpe at night in the mountains it seems like I could do better with a couple of birthday candles behind the lenses than the bulbs that are in there.
So, I purchased a plug-n-play H4 upgrade kit here - relay, sockets, bulbs the whole thing so I can see in the dark. However, I mentioned that I was going to do the H4 conversion to a fellow owner and he said that it would melt the plastic reflectors. I can't believe they would sell the kit here only to have unhappy customers when the reflectors melted behind the bulbs. Has anyone here had experience with the kits or the melting reflector problem? This morning's project (after breakfast) was to put in the kit... now???? I am a little concerned because on the caddy - we have to watch even the bulb base material - in the rear taillights - the brass base bulbs are fine - the white metal base bulbs will melt the plastic surrounds. So, as you can see in the sig Welpe is a '87 Carrera, with glass lenses in the headlights...
'Such are promises - All lies and jest - Still a man hears what he wants to hear - And disregards the rest. Lie la lie, lie la lie la lie la lie' Paul Simon '87 Black Targa "Welpe" • '93 Cadillac Allante "Amante" • Various other boring cars Last edited by foxpaws; 06-19-2011 at 12:40 PM.. Reason: new head |
RETIRED
I've never had a meltdown.....running 80/100w bulbs with relays.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
The issue with high wattage H-4s is melting the electrical connector on the bulb not the reflector. You can purchase an upgraded ceramic plug connector for this. Also be sure to add 30A relays for the high and low beams. You don't want all the current going through your switch. These two upgrades should have you well illuminating the road.
Bryan |
Liberal Prawn
Thanks guys - I have the kit and it seems to have everything mentioned above.
So later today the puppy will be able to see at night - woohoo!
'Such are promises - All lies and jest - Still a man hears what he wants to hear - And disregards the rest. Lie la lie, lie la lie la lie la lie' Paul Simon '87 Black Targa "Welpe" • '93 Cadillac Allante "Amante" • Various other boring cars |
HIDs would be a BIG night vision improvement and use LESS power, only 35W, 4300K spectrum best for human eyesight, Hi/Lo projector type available for putting light ONLY where you need it.
Liberal Prawn
Relays went in slick -
However, am I missing something or are these bulbs really different? Is there some secret handshake I don't know about? ![]()
The bulb on the left is a 9004 halogen used on cars starting in the mid-80s. The one on the right is a true H-4. If you headlamps are designed for H-4 you'll have to either replace the lamps with H-4. Two options are using a H-4 headlamp which replaces the standard round headlamp and has a bulb receptacle on the back or replacing the contents of your headlight bucket with Euro style lights. Recommend you get Euro beam pattern although not DOT legal if you go w/ H-4s as the beam is more focused than the non-descript blob on US lights. You could also just replace your 9004 bulb. You can get Silverstar bulbs for 9004 for about $20 which are brighter.
Do not repeat do not get HID concersion bulbs. To convert to HID you'll need to install BiXenon projectors and ballasts which requires some surgery and cutting your light buckets. Bryan |
Liberal Prawn
So Bryan - after all the stuff of installing the relays, cutting wires, threading wires, trying to bend my wrists in ways they don't go to get the negative wire attached correctly, etc - the kit I purchased that supposedly would upgrade my '87 headlights to H4s is basically worthless?
Why would they sell it to me - they knew what sort of car I had - everything - I even talked to them on the phone about this - can I replace the socket with this - or is this project just toast - I don't really want to spend hundreds to upgrade to different headlight assemblies - ![]() Or - does anyone have experience with the silverstar 9004 ultras - if they are decent - I'll just go with them, and strip out everything I just did... gak.
'Such are promises - All lies and jest - Still a man hears what he wants to hear - And disregards the rest. Lie la lie, lie la lie la lie la lie' Paul Simon '87 Black Targa "Welpe" • '93 Cadillac Allante "Amante" • Various other boring cars Last edited by foxpaws; 06-19-2011 at 02:05 PM.. |
Information Junky
I can't help but wonder which H4 upgrade kit you bought. --There are two. The cheap way reuses the US 'sugar-scoop' bezels. Whereas the more common 911 soln is the standard euro H4.
Do your H4's look like this... (standard Euro H4's) Also, I should add, that the wrong bulb will put the filament in the wrong place (not at the focal point of the parabolic reflector) and give results you've described.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Member 911 Anonymous
Just make certain they are aimed correctly to get the full benefit of illumination
Find a parking lot with a wall, drive up to the wall so you can get in between the wall and car then measure the height and side by side distance of each head light from the center of the lenses and place blue tape on the wall with a "X" or "+". Drive Straight back, making certain she is perpendicular to the wall 25 feet. You should see a __/ __/ pattern on the wall. The point where the light goes up should be where the "X' is. Sit in the car to insure it does not shift down, if so adjust.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 06-19-2011 at 02:47 PM.. |
Liberal Prawn
island - the kit had just the relays, wiring, new bulbs.
No headlight assembly at all - this is my current assembly ![]() ![]() So, it is looking like H4s aren't in my near future (once again - not into spending 100s on this project), however, since I have done all the work of installing the relays, can I just leave them in? Will they work if I just upgrade the bulbs to the Silverstars ultra 9004s? That way, if I have hundreds I want to throw at headlights in the future - at least part of the job would be done. And draco - once this silliness is done, I'll take your advice on aiming the lights - I am sure they will need it
'Such are promises - All lies and jest - Still a man hears what he wants to hear - And disregards the rest. Lie la lie, lie la lie la lie la lie' Paul Simon '87 Black Targa "Welpe" • '93 Cadillac Allante "Amante" • Various other boring cars Last edited by foxpaws; 06-19-2011 at 02:58 PM.. |
FoxPaws, I did the SilverStars route and it failed me, not as bright due to the blue tint and more importantly too many dead spots.
Contact Daniel Stern and get his Bulbs. They are perfect, in that they completely fill the dead spots with illumination. Worth the wait and money. With the relays I get 12.53 volts at the sockets at idle, can't ask for more. Jim Here is my write up Daniel Sterns' Bulbs: Daniel Stern Review
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 06-19-2011 at 03:01 PM.. |
The relays will help no matter what headlight you use. Since you have H5 headlights the only real fix for more light is going to H4 assemblies.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Liberal Prawn
draco - will Daniel Stern's bulbs work in the stock headlights with the stock sockets?
And do you have a link or something to them?
Information Junky
ohhh... (wincing)
Yeah, that sounds like a waste of time (and money). Your relay kit should be more than adequate for running the smaller bulbs, and allow an easy upgrade to a real (H4) upgrade.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 06-19-2011 at 03:10 PM.. |
Information Junky
I didn't see your pict's before. You may want to search on "cloudy H-5's" (you have cloudy H5's)...they can be cleaned, iirc.
Liberal Prawn
Oh - cleaning the headlights is easy - rock salt, hot water and a little vinegar - have done it on many headlights - and coffee pots. But I'll do a search and see if anything new pops up....
Southern Class & Sass
I see the fallacy in your plan. You're trying to put H4 bulbs in H5 light assemblies. Your '87 came with H5 lights. H5s may look similar to the Euro H4 assemblies, but not a single part is shared between the two. The net: What you bought is everything to do the conversion if you already bought H4 Euro light assemblies. A WTB post on the used parts forum should result in your acquiring the H4 lights you desire.
Dixie Bradenton, FL 2013 Camaro ZL1 Last edited by Dixie; 06-19-2011 at 04:56 PM.. Reason: spelling |
Liberal Prawn
thanks Rob - after all this, I sort of figured that out with everyone's help...
However, pelican didn't understand what I needed when I told them what I wanted to do with a bone stock '87 carrera, but I guess Joe Bob believes that maybe even the H5s aren't stock... Since in the midst of all this my garage door made this weird pop sound, went partially off its track and bent the track like crazy, plus it looked like it was going to fall on the cars (it at least didn't do that) any car funds will be going to garage door repair. I fear it will be just replace the bulbs with the best thing I can and clean up the H5 lenses...
