Oil cooler seals
I have read a few threads where people have used Curil-T on the engine mounted oil cooler seals. Is this necessary? I am addressing oil leaks from the three amigos and also takign care of the oil cooler whil I am in there.
If a sealent is necessary is there an alternative to curil-t?
Old 06-22-2011, 06:09 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Not necessary at all. You should install them without any sealant.
A better substance to apply to the seals, from a protection standpoint, is a silicone paste like Sil-Glyde or the Dow Corning 111 or 112 stuff. This stuff is mostly solvent resistant, so it repels oil and theoretically extends the life of the seals. Next to oil, I suspect heat is the major contributor to the demise of the seals over time?
Kevin L
'86 Carrera "Larry"
Old 06-22-2011, 07:36 AM
