-   -   What voltage at the A/C fan switch (http://forums.pelicanparts.com/porsche-911-technical-forum/615831-what-voltage-c-fan-switch.html)
migkillr 06-24-2011 07:33 PM
I'm deep, deep into replacing all the A/C components on my '83 SC...barrier hoses, evaporator, both condenser, etc..etc... and just finished the retroaire evaporator fan upgrade. It's been running good for a few days and all of a sudden...bupkiss.
Checked all the fuses under the hood, swapped relays, checked fuses in the back...nada. Using my voltage meter I get 3.6 or so volts at the fan power wire. Is is normal? Can I troubleshoot a bad switch by just jumping power over to one of the fan speed wire (low/med/hi) or should I be using a 12 volt source to see if the fan motor is okay? Did I mention it's all brand spanking new?
Thanks,
Dean
DRACO A5OG 06-24-2011 07:45 PM
Need to check voltage at the connector of the blower in the smugglers box:
Compliments of Gerry 86 911 Targa
Current:
Blower (Evap) Motor Lo
https://mail.google.com/mail/?ui=2&i....3&disp=thd&zw
Blower Motor Med
https://mail.google.com/mail/?ui=2&i....4&disp=thd&zw
Blower Motor High
https://mail.google.com/mail/?ui=2&i....5&disp=thd&zw
Voltage at High:
https://mail.google.com/mail/?ui=2&i....1&disp=thd&zw
Note this data is off of 84-86 3.2
Also check A/C fues #2, if it is loose due to heat shrinkage.
For my issue I re-placed the fuse block and rails for $26: http://forums.pelicanparts.com/porsche-911-technical-forum/613548-fix-3-2-c-2-fuse-finally.html
migkillr 06-24-2011 08:10 PM
Did something get lost in translation? I don't see any numbers?
DRACO A5OG 06-24-2011 08:20 PM
Really? you don't see the images? I see 4, No?
Try to reload the page, F5
Originally Posted by DRACO A5OG (Post 6099273)
migkillr 06-24-2011 09:32 PM
Well,
I still don't see them, but I have solved the problem and thank you for the input. In my case, it ended up being a loose relay. Really barely noticeable that one was sticking out a little more on the fuse box than the others....really hard to notice. Fans are all back on and I'm breathing easier. Now to finish up!
DRACO A5OG 06-24-2011 09:42 PM
Cool :D
