mechanic in Ventura County Calif?
Anyone recommend a good mechanic in Westlake, Thousand Oaks, Oxnard, Camarillo, or Ventura area. If it was a major repair I'd go to TRE (Tyson did my PPI) but this is minor, I overlooked my dreaded smog test notice and its due in 2 days. I don't have time to swap out the bypass, SW chip and M&K. Thanks
RayM 86 Carrera 95 ///M3 87 924s (track) Last edited by RayM; 06-14-2007 at 11:55 PM.. |
I know of three:
Autobahn West in Agoura Hills. Don't know anything about quality or experience. Porsche only. RS something, Jason Duarte, in Ventura. He did some work on my car, made a mistake that required the engine/tranny to be pulled and the tranny taken apart. He did it and stood behind his work, though he did make the mistake. Schneider in Santa Barbara. Good reputation, no personal experience. |
Jason Duarte in Ventura at RS Enterprises is a stand up guy that does good work. Everyone can make a mistake but not many admit it or correct it.
Another vote for Jason @ RS if TRE is unavailable.
Dan Byers |
Large Registered Member
The SW Chip can stay. I can't see any problem leaving the MK Muffler there... However, definitely swap the Cat back in. Make sure the Cat is TOASTY hot before pulling in to get the check done. Fresh oil change is a good idea too... You might be able to get into a muffler shop to swap the CAT back in...
'85 Carrera Coupe, Marble Grey #118 JP/R6 '93 Lexus SC400, '00 Ford F-150 '70 911T- 2.7 (SOLD) |
+1 for Jason at RS Enterprises.
He did my suspension work when I first got my car and was living in Westlake Village.
1989 Carrera 3.2 Silver Anniversary Edition 2007 BMW 750Li 2005 Honda Odyssey EX-L http://forums.pelicanparts.com/porsche-911-technical-forum/285064-new-member-have-pics.html |
loose nut behind wheel
Try Europa in Moorpark
80 911sc/993 GT-2 body/3.6L motor 71 VW Convert (300 hp 2332 FI turbo) 97 Passat TDI 320K miles and counting |
Automotive Monomaniac
Another A+ for Jason at RS. My car died one day and he stayed late to wait for the flatbed... very honest guy.
I've also had excellent experiences at TRE, but they are a bit harder for me to get to (I work in Camarillo).
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
Thanks for all the help guys. Jason squeezed me in at the last mintue and gave me a 3:30 appt and then after getting stuck in the early Friday getaway on the 101 I got there 20 minutes late and after apologizing he said no problem. swapped out the bypass and found the extra hardware I forgot for my heatshield and got me out at 5:15. Best part was while he was wrenching I was checking out his monster 935 clone he has in the shop.
Can't wait to get the car tested so I can put back in the bypass. I conpletely lost a raspy throaty exhaust sound especially at higher rpms and letting off the throttle.
RayM 86 Carrera 95 ///M3 87 924s (track) |
Glad it worked out.
Yes, his 935 clone is a beast.
Paul Brotea in Ventura .
Ventura Independent on Palma . No substitute
Sure I can drive a stick ! |
RS Enterprises
Jason did an awesome PPI for my 911. I was overseas at the time and he really worked with me and the dealer to get it done. and the car is awesome. Highly recommend RS Enterprises
I believe Europa in Moorpark is closed. Schneider in Santa Barbara is excellent. Also Mikes Foreign Sports in Thousand Oaks is Very good.
Mike Schatz @ MKS performance in Camarillo.
Certified Porsche Premiere Master Technician. ... also one of the few certified to service the Carerra GT Very good with CIS injection Excellent EFI diagnostics 805 657 3217
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
Max Sluiter
They are no longer in business, R.I.P. Pete.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Ventura mechanic
+10 for Mike Schatz @MKS Performance. I drive by a Ventura mechanic to drive to Camarillo for honesty and an excellent mechanic.
Kevin |
+1
Dan |
Canyon Runner
1 + Mike, He's the man + One cool guy & a good tech . He once came to my house to check on a problem for me . Now how often can you find that kind of service .
You really don't need to put the shield on. Just extra work and isn't needed.
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
